Author: Subject: blacktop coolant diagram with heater
zetec-phill
posted on 20/1/13 at 01:40 PM Reply With Quote
anyone got a coolant diagram for black top incorprorating a heater
a using rover expansion bottle
Dooey99
posted on 20/1/13 at 05:56 PM Reply With Quote
Sorry i dont have one for a heater but if you use this one, the blanked off hose on the thermostat run that to the heater inlet and then run a hose from the heater outlet and use a T piece to connect it into the hose that comes off the bottom of the header tank as far away from the tank as possible (as close to where the hose off the bottom of the header tank T's into the hose already on the diagram.
Hope this helps.
zetec-phill
posted on 20/1/13 at 06:14 PM Reply With Quote
Thank you, ill go that way
big_wasa
posted on 20/1/13 at 07:21 PM Reply With Quote
The heater just returns to the bottom hose along with the bypass and the header tank.
ludsonline
posted on 8/2/13 at 06:14 PM Reply With Quote
Like this?.
posted on 8/2/13 at 06:24 PM Reply With Quote
No, not like that, heater returns into the bypass hose promoting quick heat up during thermostat closed position.
Going into the header tank hose there will cause surge. Dont do it!
posted on 8/2/13 at 06:36 PM Reply With Quote
Ford zetec bypass hose OEM.
Bigger hose outlet on left goes to bottom hose close to water pump, two smaller inlets on right are from the thermo housing bypass and the heater return.
