<<  1    2    3    4    5  >>
Author: Subject: A New Project, GT6 aluminium body
deezee
posted on 13/2/13 at 08:23 PM Reply With Quote
I've included the full address of the photos
Riskyshift
posted on 13/2/13 at 09:03 PM Reply With Quote
Like it. Subscribed to the thread.
Ian
John Bonnett
posted on 13/2/13 at 09:49 PM Reply With Quote
Ian
Thank you Ian. There will be a bit of a break now for a few weeks because a couple of holidays are getting the way
John Bonnett
posted on 14/2/13 at 04:11 PM Reply With Quote
Thank you very much for doing that. If you could tell me how you did it I'll be able to upload more pictures.
regards
John
40inches
posted on 7/3/13 at 09:03 PM Reply With Quote
I used to think I was a bit too fussy getting things correct, your work makes everything that I have ever done look like a bodge
John Bonnett
posted on 7/3/13 at 09:12 PM Reply With Quote
Now, come on. I've been looking through your photo archive and your workmanship is of the highest quality and something to be very proud of.
On my project, I've been beavering away slowly but making progress. The gutter under which the tailgate fits has slowed me down while trying to find a way to make it using my limited skills but I hope I've come up with the answer.
I've just two pieces left to make before the panels that I've made can be welded together to make a complete roof.
I've been able to upload the pictures now so thank you Chris for sorting out that little problem but I've forgotten how to include a fullsize picture in my post.
Ah, now sorted
[Edited on 9/3/13 by John Bonnett]
John Bonnett
posted on 14/3/13 at 09:16 PM Reply With Quote
I was hoping to have all the roof panels finished by now and ready for welding but have suffered a bit of a delay.
I'm getting a bit old and senile and the first thing I didn't notice was that I had turned the flange for the gully (N/S tailgate gully) up instead of down and to make matters worse, the lower wheel on the jenny had slipped backwards so that I had two knife edges top and bottom instead of just at the top. Result was a wonderfully crisp fold but a deep score as well. So no chance of reversing the fold and therefore, I had no choice but to bin the panel and start again. The good news is that its replacement completed in a fraction of the time, is actually a truer shape than its predecessor and the flange turned down properly this time; nice fold and the right way. So not all bad. Just the lower horizontal to make now and then time for trimming and welding.
Volvorsport
posted on 15/3/13 at 12:29 AM Reply With Quote
what wheeling machine do you have ?
any pics ...?
www.dbsmotorsport.co.uk
getting dirty under a bus
Not Anumber
posted on 15/3/13 at 09:23 AM Reply With Quote
+ 1
It would be very good to see the equipment you are using to fabricate these remarkable curved panels and even better to have a few pictures of you actually using it.
John Bonnett
posted on 15/3/13 at 12:59 PM Reply With Quote
I'm afraid my equipment's not very impressive
But in my workshop I have an Edwards wheeling machine, a shrinker/stretcher and a beading machine or jenny. I don't have any motorised or power tools like and Eckold or Pullmax.
Anyway here is my E.Wheel
And a couple of pictures showing the lower tailgate aperture panel being developed. I wheeled a bit of curvature into it before turning the flange on the jenny.
This is a picture showing the jenny with the side panel.
Pictures of lower panel
The next thing is to trim and turn down the flange for the gutter
John Bonnett
posted on 15/3/13 at 05:18 PM Reply With Quote
Well it started off quite well but went wrong at the end. I may be able to save it but most likely will start again after a bit of a rest.
http://farm9.staticflickr.com/8365/8560351208_4efec61f07.jpg
[Edited on 15/3/13 by John Bonnett]
John Bonnett
posted on 18/3/13 at 02:01 PM Reply With Quote
I have indeed started again and changed the approach to make it a bit easier. The crease on the bottom edge will now be in the deck panel rather than this one. This has simplified things no end because the gutter return and the crease no longer have to be perfectly aligned.
John Bonnett
posted on 24/3/13 at 09:54 AM Reply With Quote
Suffered a small set-back after having welded the lower gutter section onto the side roof panel I noticed that along its entire length, the weld was full of porosity; loads of tiny pinholes. Serves me right for using four year old flux! The odd thing is that the test pieces were fine.
I mentioned this to Trev D and strangely enough, using the same make of flux, he has also had problems but in his case cracking of the weld. I've been recommended a really good flux from TM Technology which I have just ordered up This is coming from the States so there could be a delay before I can crack on.
boober
posted on 24/3/13 at 06:30 PM Reply With Quote
hello john
is the crack at the start of the weld bead,or further in.
John Bonnett
posted on 25/3/13 at 07:37 AM Reply With Quote
Originally posted by boober
hello john
Trev didn't say but no crack on my weld Mark, just porosity.
There are many variables which will affect the weld and apart from the flux and filler not the least is the preparation of the material prior to welding. I perhaps wasn't meticulous enough in removing every trace of aluminium oxide. So, from now on I'll be more aggressive with the stainless steel wire brush and be absolutely certain that every trace of oxide has been removed.
[Edited on 25/3/13 by John Bonnett]
ceebmoj
posted on 25/3/13 at 09:27 AM Reply With Quote
Do you have photos of the weld and other progress? I ask because I have no idea how a body is made like this and have found this a very interesting thread.
John Bonnett
posted on 25/3/13 at 11:11 AM Reply With Quote
If you look at the pictures I posted earlier in this thread, you will see that the roof is made up of a series of sub-panels which are welded together and then planished (smoothed) to finish the complete panel. Gas welding is preferred because the weld bead is soft and malleable and can be easily flattened back into the parent material.
Here are a couple of pictures of a weld I did on a test piece. The second picture shows good penetration on the reverse side of the weld.
John Bonnett
posted on 26/3/13 at 05:46 PM Reply With Quote
My good friend Mark has let me have a sample of the TM Technology flux which I have now tried and not only has the porosity problem disappeared, the resulting weld has never been brighter or cleaner. So, that little problem seems to be behind me.
I managed to salvage the roof side panel and just needed to cut off the gutter just above the weld line. Picture attached showing new lower gutter ready to be welded on.
Once done, the rest of the roof panels will be finally trimmed and ready to be welded together.
boober
posted on 26/3/13 at 05:50 PM Reply With Quote
good camera skills john do you do weddings
John Bonnett
posted on 26/3/13 at 05:51 PM Reply With Quote
I do a good Best Man's speech!
ceebmoj
posted on 26/3/13 at 09:07 PM Reply With Quote
How do you chose where to join the panels? when you flatten the welds does that not reshape the panel?
John Bonnett
posted on 26/3/13 at 09:38 PM Reply With Quote
Good questions, both of them. I'm only a self-taught amateur and we'd need Trev D to provide a complete answer. But I do know that choosing where to put the joints needs a bit of thought and planning. For minimum distortion during welding it's best to put the join on a curve but it needs to be an outward curve to be able to planish it. If it were an inward curve it would be impossible to use a body file. Generally, from a shaping point of view, joins would be needed in areas where there is a severe change in curvature or where a large amount of shrinking or stretching is needed. or just to reduce the size of the panel into a manageable piece. So there are a number of factors that contribute to the decision.
The second question is also bang on the nail. Flattening the welds and pushing the metal back into itself can easily stretch the material and change its shape. So it's good to keep the weld bead and the penetration to a minimum during welding and to file off the the bits of the bead that are proud before planishing. This leaves the minimum of work to do with a hammer and dolly.
John Bonnett
posted on 3/4/13 at 01:17 PM Reply With Quote
With all the roof panels formed, I'm now at the welding together stage so progress is being made; albeit slow.
John Bonnett
posted on 6/4/13 at 04:41 PM Reply With Quote
I've just completed welding the roof panels together and, amazingly, the assembly fits the buck so, happy days. There was hardly any distortion during the welding process which was an unexpected bonus.
I'm now faced with a job that I find really challenging; even more than the welding. The metal finishing, bringing up the lows and planishing to a nice smooth curvature. Hammer and dolly in the hands of a professional looks so easy but what job doesn't when carried out by a skilled man?
John Bonnett
posted on 20/4/13 at 02:43 PM Reply With Quote
Work has been progressing steadily with many hours spent bringing up the lows on the roof. We are not quite there yet but there has to be a point at which one says, that's good enough. I'm not quite at that point yet but not far off.
The panel rear of the quarter light was an interesting one to make with the reverse curve. I managed that one okay but I now have to make another one for the other side and I always find the second one more difficult.
The three tailgate aperture panels are now welded but I can't weld them to the roof until I've finished the planishing but more importantly until the panels immediately beneath are in place to provide rigidity.
A few pictures attached.
<<  1    2    3    4    5  >>
