Author: Subject: 205 60 13 tyres
Apollo1600
posted on 9/2/13 at 11:33 AM Reply With Quote
205 60 13 tyres
Hi there,
I'm after some 205 60 13 tyres, has anyone got any?
pewe
posted on 9/2/13 at 12:00 PM Reply With Quote
If you're after new then Camskill sell Falkens which I've found to be OK on the Formula27.
linky
Local tyre fitter should charge between £5 & £10 a cover to fit depending on what part of the country you're in.
HTH.
Cheers, Pewe10
adithorp
posted on 9/2/13 at 12:05 PM Reply With Quote
I've got some worn Toyo 888's. Some tread left on them. They were removed as tread wasn't enough to get through a 3000 mile euro tour with confidence there'd be much left on the return run. About 3mm left on them all.
2 are standard and 2 have been cut to improve wet grip; Only the blind groves opened up to the edge but that makes a huge improvement. Got a couple of 185/60/13's as well.
http://jpsc.org.uk/forum/
