Author: Subject: Stripped thread
billy
posted on 17/2/13 at 08:29 PM Reply With Quote
Stripped thread
Hi lads, I stripped the thread on a wheel hub, has anyone had this problem and fixed it with helicoiling the thing? I only say it as it's been suggested as a option to fix the problem. I've no idea how it's done but don't fancy changing the whole hub. Anyone???
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
madteg
posted on 17/2/13 at 08:56 PM Reply With Quote
Hell of a way to test a helicoil. ( Change the hub).
posted on 17/2/13 at 09:16 PM Reply With Quote
Helicoils are great for threads that don't need to be repeated dismantled i.e. anything but wheel bolts.
loggyboy
posted on 17/2/13 at 09:37 PM Reply With Quote
Convert to studs?
Mistral Motorsport
tilly819
posted on 17/2/13 at 10:02 PM Reply With Quote
What he said
Tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
coyoteboy
posted on 17/2/13 at 10:19 PM Reply With Quote
+2
daviep
posted on 17/2/13 at 10:55 PM Reply With Quote
I would install a helicoil without hesitation, there is no limit to the number of times that the srew can be assembled/disassembled. In fact it is considered good practice to helicoil threads in soft materials as it allows a higher torque to be applied and prevents the thread wearing out if assembled/disassmbled frequently.
Davie
p.s. Use a quality brand such as "Recoil" and have a couple of practices as there is a technique to fitting the insert correctly.
coyoteboy
posted on 18/2/13 at 12:56 AM Reply With Quote
My past experiences with helicoils do tend to make me wary of them on frequently disassembled joints, they can and do work loose if their fitment is not A1 perfect, though only when disassembling, not in operation.
billy
posted on 18/2/13 at 06:43 AM Reply With Quote
Thanks lads, I like the sound of replacing with studs but it's on the rear of a escort, not quite sure how it will work?
