New Topic New Reply
Author: Subject: Mk Indy, what ET are you running?
fullpint
posted on 21/2/13 at 07:20 PM Reply With Quote
Ok its asked many times. Ive done the search and also looked n willitfit.com
So my Mk Indy blade is on 15 x 6.5 et37. I really want to go down to 13's but having trouble finding a set with the exact ET.
So is anyone running 13 x 7's with an et of 24mm?
According to my workings the out board flange will be about 20mm further out and about 7mm further out on the in-board flange.
Kev99
posted on 21/2/13 at 07:55 PM Reply With Quote
Im running pro race 1.2s 13" et35
whitestu
posted on 21/2/13 at 08:47 PM Reply With Quote
Mine are also pro race 1.2s and either 35 or 38 et
Stu
40inches
posted on 21/2/13 at 08:52 PM Reply With Quote
Mine are 35 too.
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 21/2/13 at 11:00 PM Reply With Quote
I can get pro race wheels for a reasonable price if you're interested.
Send me a u2u
Twin40
posted on 22/2/13 at 07:49 AM Reply With Quote
Hi there, I'm running 13" compomotives which are et20 all round (i think!)
renetom
posted on 22/2/13 at 10:03 AM Reply With Quote
Hi
We are running 13" compomotives 35 et
Good luck
PAUL FISHER
posted on 22/2/13 at 12:01 PM Reply With Quote
With the standard indy rear arches 7" et 24 will not fit, you require et 35.
Mk do extra wide arches, then you can fit et 24 no problem, you can even go up to a 8" rim.
fullpint
posted on 22/2/13 at 03:09 PM Reply With Quote
Ok I will continue my hunt for 13's with the correct ET. Cheers chaps, much appreciated.
parkiboy
posted on 1/3/13 at 08:07 AM Reply With Quote
It's quite difficult I think? I wanted some monilites but most of them are et -7 :-( finding it rather hard to find some
jps
posted on 1/3/13 at 09:00 AM Reply With Quote
...how come so many people run 13" wheels, when it looks like the minimum I can get away with on my Haynes Roadster will be 15" (in order to clear the rear wishbones). I thought the Haynes and the Indy were similar designs. Does the Haynes have an unusually broad rear wishbone setup?
whitestu
posted on 1/3/13 at 09:05 AM Reply With Quote
People run 13s beacuse unsprung weight is lower. Personally I think that size looks better as well.
If the Haynes uses Sierra components then I would have thought 13s were possible. I guess it depends on the rear upright. The front should be the same if the Sierra upright is used.
Stu
parkiboy
posted on 10/3/13 at 10:45 AM Reply With Quote
While on the subject of 13" wheels, before I consider purchasing any, my car ha the willwood brake upgrade on the fronts, will 13's fit over them?
rdodger
posted on 10/3/13 at 07:08 PM Reply With Quote
I have Prorace 1.2 13" ET35 over 260mm Wilwood Midilite. Sierra uprights.
New Topic New Reply
