<<  1    2  >>
Author: Subject: Fisher Pedal Box Options
alan87
posted on 21/2/13 at 10:12 PM Reply With Quote
Hi guys,
I've been doing quite a bit of research, but can't seem to see a definitive answer.
Has anyone used a different pedal box in their fury? If so what have you used?
Looking at the OBP boxes, but with some quick measurements I don't think it will fit?!?
Alan
jeffw
posted on 21/2/13 at 10:31 PM Reply With Quote
Suggest you speak to Steve at Fury Sportscars...
encyd
posted on 22/2/13 at 11:51 AM Reply With Quote
Originally posted by alan87
Hi guys,
Alan
I had a look for mine which is based on the old escort pedals with the master cylinder on top. I couldn't find anything to fit so renovated what I had. If it's the old style with the sloping footwell it makes life even more difficult.
Good luck and please report back if you do find a solution!
FuryRebuild
posted on 22/2/13 at 01:06 PM Reply With Quote
I did a load of work on mine - and fitted an OBP box.
However, the work wasn't trivial.
There are some posts on my blog here and this forum post here
cheers
Mark
www.furyrebuild.co.uk
alan87
posted on 22/2/13 at 06:14 PM Reply With Quote
Thanks Mark,
I had seen yours already, certainly a lot of work!
I'm sure I had seen somewhere that OBP would consider making a specific fury box if there was enough interest, but I can't seem to find it anywhere!?!
Jeff, Steve was my next port of call. Are you still using the standard sylva / fisher pedals?
richiekuk
posted on 14/3/13 at 10:23 AM Reply With Quote
Hi.
Sorry to hijack, but did anyone find a pedal box that would be suitable for a fury.
I have a 2006 chassis, with the standard fisher pedal box (flimsy). I would like a new floor mounted box.
I would be quite happy with just the brake and clutch, as the throttle i have is more than adequate for the time being.
I would be after a cable clutch, and dual master cyclinder brake, with bias bar.
Any help as to what would fit would be greatly appreciated.
Richie K
alan87
posted on 14/3/13 at 04:25 PM Reply With Quote
Hi Richie,
I Contacted Steve at fury sports cars, and believe there is now a better engineered version, however after the initial email I haven't heard any further.
I have however today contacted Sam at Obp to see if they would add a fisher specific box to their range.. As soon as I hear anything back I'll update this thread.
jeffw
posted on 14/3/13 at 06:07 PM Reply With Quote
Thanks Mark,
Sorry missed this, yes, still have the stock top mount.
richiekuk
posted on 15/3/13 at 09:41 AM Reply With Quote
Hi Richie,
Thanks.
Look forward to hearing
Richie K
FuryRebuild
posted on 15/3/13 at 09:46 AM Reply With Quote
It would be good if they could - the only thing I really changed was to narrow the box by 1" and to take a corner around. However, that was to fit my duratec footwell, rather than a standard one.
good luck.
One of the nice things about OBP and Sam was that they contacted me after I had copped my pedal box to say "cool - our director liked what you did there" which was the nicest response I could hope for.
A friendly company helps.
M
richiekuk
posted on 17/3/13 at 01:55 PM Reply With Quote
http://www.compbrake.com/pedal-boxes/floor-mounted/-3007.html
http://www.obpltd.com/obp-shop/race-car-pedal-boxes/universal-floor-mounted-pedals/kit-car-all-in-1-range/2-pedal-floor-mounted/2-pedal-cable-clutch/2 -pedal-floor-mounted-cable-ctutch-0f76
Wonder if something like this would be good, as I'm happy with the standard throttle.
Obviously the throttle will hang down next to the brake pedal, so may be ok.
Richie K
[Edited on 17/3/13 by richiekuk]
Furyous
posted on 20/3/13 at 07:01 AM Reply With Quote
I'd be interested in an OBP box designed for the Fury.
I was close to buying a Tilton 600 set. Tilton 3 Pedal Floor Mounted Brake Pedal Box 72-603 | eBay It's about 270mm wide, so I measured up the footwell from the outside and it should just about fit. I found one on TradeMe.co.nz for a very good price. After double checking the measurements before plonking a wad of cash on it, I realised the bottom of the footwell is only about 200mm. Even the two pedal version is too wide for that. Shame, because the Tilton pedals feel very nice.
richiekuk
posted on 20/3/13 at 10:10 AM Reply With Quote
I've just spoken to OBP, and they are more than happy to make a Fury specific pedal box.
They just need measurements and maybe some diagrams of exactly what we are after.
We may pay a premium for a custom box, but it could well be worth it, cost depending.
How many others would want an OBP box, and what would you want: 2 pedals (clutch and brake), 3 pedals. Hyd clutch, cable clutch?
Would it be possible for someone to get the relevant measurements, as I'm away until Easter.
Cheers.
Richie K
Furyous
posted on 20/3/13 at 07:27 PM Reply With Quote
I'd want 3 pedals and a hydraulic clutch. My main complaint with the standard pedals is that the throttle is so flimsy. I also need to change from a cable clutch pedal to hydraulic.
I don't want the responsibility of measuring up, though. I tend to be a bit slack with measurements.
If OBP can make a custom Pro-Race pedal box for under £250, I'd buy one.
richiekuk
posted on 20/3/13 at 07:35 PM Reply With Quote
I wonder if they could do one where you could either have a cable clutch or hydraulic.
I don't mind measuring up, but I won't be back home until a week Friday.
Richie K
alan87
posted on 20/3/13 at 09:33 PM Reply With Quote
Great work, thanks for chasing up as Sam hadn't got back to me by u2u.
Definitely up for one. I would be happy with just 2 pedals but could accommodate 3.
I would want hydraulic clutch as well.
Ritchie maybe if you measure and post them on here a few of us can double check against our own chassis?
Also might be worth asking over on jpsc & Sylva chat list.
FuryRebuild
posted on 20/3/13 at 09:56 PM Reply With Quote
Another advantage of the obp box is that you don't have the throttle pedal protruding out, giving a hole between your feet and the engine bay. This is a fail. This also assumes you film the hole in.
richiekuk
posted on 29/3/13 at 04:14 PM Reply With Quote
Im hopefully going to get to the car tomorrow and take some measurements to send to OBP.
I hope they can come up trumps and do us a nice pedal box.
richiekuk
posted on 1/4/13 at 03:21 PM Reply With Quote
Here are my "rough" measurements. I say rough, but they are as near as makes no difference I think.
Anyone else managed to measure so we can compare, before I ring OBP.
Richie K
alan87
posted on 1/4/13 at 08:48 PM Reply With Quote
Ritchie,
I should be able to get into the garage tomorrow afternoon. I'll do some measuring and let you know.
Alan
alan87
posted on 3/4/13 at 10:57 AM Reply With Quote
Ritchie,
I agree with those, so unless anyone else has measured differently I would be happy to put those forwards to OPB
Alan
richiekuk
posted on 3/4/13 at 07:23 PM Reply With Quote
I've had a reply from OBP.
They say a 3 pedal box would not be possible, but they have dimensions for a 2 pedal box measuring 191mm across
I, personally, would be happy with this. I would live with the top mounted throttle for the time being.
They sent me some links
Dimensions:
http://www.obpltd.com/help/file/12-2-pedal-floor-mounted-bulkhead-fit-pedal-box-system
richiekuk
posted on 3/4/13 at 07:29 PM Reply With Quote
I also noticed today that the footwell floor flexes when i press the clutch. Anyone fixed this issue?
Richie K
alan87
posted on 3/4/13 at 07:31 PM Reply With Quote
That looks fine to me. what price do they reckon for that?
richiekuk
posted on 3/4/13 at 09:17 PM Reply With Quote
They linked me to a page on their website, so I imagine the price would be as per that.
<<  1    2  >>
