Author: Subject: Vauxhall Astra Van
Dunbikin
posted on 25/2/13 at 07:48 PM Reply With Quote
Vauxhall Astra Van
Hi all,
I would just like to pick your brains if I may. I have an 04 astra van 1.7 cdti, engine code Z17DTL. The van over heated the other week and I have been told by the garage today it needs another engine. I've been looking on the Bay and CDTI engines are going for about £800, but DTI engines are going for £300 - £400 (same engine code Z17DTL) . Sooo... my question is, could I get a DTI engine and fit the common fuel rail to it to convert it to CDTI.
Thanks for your time
Nigel
Ron said it would cost 250 quid. My wife thinks it did.
morcus
posted on 25/2/13 at 09:43 PM Reply With Quote
I don't know enough to say, but it seems reasonable that you could. Do you know whats salvagable from the current engine?
Ninehigh
posted on 26/2/13 at 01:20 AM Reply With Quote
I get the feeling that the cdti engines you're looking at are somewhat different to the one you have, and the dti ones are the same just labelled differently. Not that I'd know any of it
snapper
posted on 26/2/13 at 07:59 AM Reply With Quote
Fuel rail pressure, I believe, is much higher than in the DI engine
So assume fuel pipes and pump could need changing
ECU will as some key the injectors to the ECU
On the surface it all seems easy but when you dig deep it becomes more work than its worth
I eat to survive
I drink to forget
Dunbikin
posted on 26/2/13 at 06:54 PM Reply With Quote
Thanks for the replies chaps...Given me some food for thought.
Should be all the engine, apart from cylinder head.
