Author: Subject: MK Indy Auto For Sale
MautoK
posted on 8/3/13 at 04:00 PM Reply With Quote
My MK Indy Automatic is up for sale.
Unfortunately, all my old posts seem to have disappeared, so briefly:
MK Indy 2L Pinto Automatic.
Chassis 2003 with wider tunnel to accommodate bigger gearbox
3.38 diff
SU carbs
12" steering wheel
Completed & SVA March 2009
Less than 1300 miles; SORN 2012 & 2013
Gearbox input shaft oil seal leaking.
Front engine seal minor weep.
Otherwise all good.
It would suit someone looking to fit a different engine/trans without having to build the car.
Looking for £3250 to include some spares:
Spare 2L engine
A4LD box - needs rebuild
Water pump
Std Steering wheel
Some EDIS bits
Type 9 in bits (cleaned & painted)
Need to release garage space.
I'm only doing about 1500/yr in my tintop!
Wes
posted on 8/3/13 at 10:50 PM Reply With Quote
Pmd
MautoK
posted on 4/5/13 at 03:47 PM Reply With Quote
Summer's coming and the car wants a new owner to play with it!
MautoK
posted on 24/6/13 at 06:16 PM Reply With Quote
Still here!
jacko
posted on 24/6/13 at 07:11 PM Reply With Quote
Hi Mate i hope you are well
You will just have to keep using the indy and let it grow old with you
Are my SU's still working as they should
Graham
MautoK
posted on 9/7/13 at 07:54 PM Reply With Quote
Bump!
graham-e
posted on 13/7/13 at 02:43 AM Reply With Quote
MOT wise, do you recon it should fly through? or is there anything that will need seeing too like the oil leak?
MautoK
posted on 9/8/13 at 04:57 PM Reply With Quote
...bump...
MautoK
posted on 15/8/13 at 11:45 AM Reply With Quote
Will let everything go for £3100. Buyer sells any bits they don't want...
