<<  3    4    5    6    7    8    9  >>
Author: Subject: "How to" OEM zetec ecu with Pats info.
snowy2
posted on 6/6/16 at 08:14 PM Reply With Quote
My working diagrams for the Focus 60 pin ECU......I used the pin out list earlier in this post.
sometimes you are the pigeon, most of the time the statue.
snowy2
posted on 6/6/16 at 08:18 PM Reply With Quote
Key...
red = 12v battery.
green = 12v ignition switched.
blue = connection to ECU
Orange = connection to components.
The cooling relay has a anti spiking diode built in (the green relay) this protects the ECU from reverse voltage spikes when the fan shuts down...
snowy2
posted on 6/6/16 at 08:20 PM Reply With Quote
The second relay down has an orange connection. ....it connects to the ignition switch "run" position. .
big_wasa
posted on 6/6/16 at 08:22 PM Reply With Quote
Thanks for the cooling fan relay info I've never got as far as looking into this. I've always run a direct switch from the rad or top hose. Have you had if upto temperature and checked the operation.
[Edited on 6/6/16 by big_wasa]
snowy2
posted on 6/6/16 at 08:29 PM Reply With Quote
Not yet....just built an exhaust for it (pepper performance 4-1 manifold...
as yet no coolant in system but next week end I hope.
snowy2
posted on 6/6/16 at 08:46 PM Reply With Quote
My project ......had to make the exhaust so I can finalise the cooling plumbing. ...ignition "on" and cooling relay next to battery...all other fuses and relays on other side of engine bay.
Zetecsierra
posted on 5/10/16 at 12:40 PM Reply With Quote
Would the blacktop pinout work for a LAAN mondeo ecu for my sierra
Originally posted by big_wasa
WARNING I WILL NOT BE HELD RESPONSIBLE FOR ANY LOSSES OR INJURY RESULTING FROM USE OF THE INFORMATION CONTAINED WITHIN THIS POST.
As this is locost builders there are some people left that love to tinker and make things.
This is to give those people that are interested in running a ford efi engine on a budget a little more info on how the Immobilizer can be used out of the donor car.
The key to using the the ecu is the Pat's immobilizer. You must get atleast one key with chip that is matched to the ecu.
You can not bypass it but you can use it.
Silver Top
The following pinouts are ONLY for the ecu with the code OWLS but with the info you can often work out other ecu's
Ford 104 pin Mondeo 1997 “owls” ecu plug.
Missing numbers have no connection and are not used on the owls ecu or the function has not been found. This is still under development.
Pin number -- colour -- function.
08 yellow/green -- Pats
13 white/blue--Data Link connector.
15 blue-- Data Link connector.
16 grey-- Data Link connector.
19 grey/orange -- Pats TX signal.
20 black/blue -- Injector 3 switched earth.
21 white/red -- crankshaft position sensor +.
22 brown/rd --crankshaft position sensor -.
24 black/yellow -- ground
25 black/red -- ground separate earth @ ecu plug.
26 brown/blue -- switched earth coil 1 (pin 1 on coil).
27 black/yellow starter relay inhibiter
30 white/black -- octane plug
36 brown/blue -- MAF.
38 white/green -- Engine coolant temp sensor.
39 white violet -- Air temp sensor.
40 violet/black -- fuel pump monitor.
42 black/blue -- PATS Led.
48 white -- Tacho.
51 black/yellow -- ground.
52 brown/blue -- switched ground coil 2 (pin 3 on coil)
53 white/green -- Pats RX signal.
54 black/blue -- fuel pump switched earth.
55 orange/yellow Pin 10 c2513 KAM perm live.
60 white -- HO2S 1 signal
70 black/white -- injector 1 switched earth.
71 green/yellow -- switched 12v from power relay.
76 brown/white -- Cam position sensor.
77 black/yellow -- ground.
83 green/yellow -- idle air control valve.
85 white violet -- camshaft position sensor.
88 white/blue -- MAF.
89 white -- throttle position sensor.
90 yellow -- 5v Voltage Reference (tps)
91 brown -- sensor common.
93 black/yellow -- HO2S 1 control (earth).
95 black/orange -- injector 4 switched earth.
96 black/yellow -- injector 2 switched earth.
97 green/yellow -- switched 12v.
103 black/yellow -- earth.
Black Top
Ford 104 pin Mondeo 1999 “owl5” Pcm plug. C401.
17 black/white -- to PIN 25 on c2513.
19 grey/orange -- to Pin 32 on c2513 Pats TX signal.
24 black/yellow -- ground pin 9 on c2513.
25 black/red -- ground separate earth @ Pcm plug.
26 black/blue -- switched earth coil 1 (pin 1 on coil).
27 black/yellow -- pin 36 on square c2513 start inhibit relay circuit. ???
28 white/violet -- pin 13 on c2513 vehicle speed signal ( split to Pcm and dash).
31 white -- pin 7 on c2513 Power steering pressure switch. ???
36 brown/blue -- Pin 4 on square c2513 MAF return.
38 white/green -- coolant temp sensor (P1 mini timer)
39 white violet -- Air temp in MAF (P1 Maf plug)
40 violet/black -- Pin 19 c2513 fuel pump monitor.
41 violet/blue -- Pin 23 c2513 A/C clutch pressure switch.???
42 black/blue -- Pin 6 c2513 PATS Led. ???
43 white -- Pin 28 on c2513 sensor signal white. ???
47 black/green -- vacuum solenoid valve control (pin 2 small plug).
48 white -- Pin 30 on c2513 Tacho.
51 black/yellow -- Pin 9 on c2513 ground.
53 white/green -- Pin 35 on c2513 s Pats RX signal.
54 black/blue -- Pin 5 on c2513 fuel pump switched earth.
58 white/blue -- Pin 2 on c2513 Vehicle speed Sensor.
59 white/green -- Alternator monitor circuit (Pin 2 on alt plug)
64 white -- Pin 39 c2513 clutch switch.???
65 white/green -- exhaust pressure transducer signal(large plug )
67 black/orange -- Pin 18 c2513EVAP canister vent control . ???
68 black/blue -- Pin 20 c2513 switched ground black/blue ???
69 black/yellow -- Pin 27 c2513 switched ground. ???
77 black/yellow -- Pin 9 c2513 earth.
83 green/yellow -- idle air control valve (pin 2).
86 black/blue -- Pin 40 c2513. ???
88 white/blue -- MAF output.
89 white -- throttle position sensor (pin 2)
90 yellow -- 5v Voltage Reference (5v out from ecu)
91 brown -- Pin 38 c2513 + sensor common brown
93 black/yellow -- HO2S 1 control.
97 green/yellow -- Pin 1 c2513 switched 12v.
103 black/yellow -- Pin 9 c2513 earth.
“DLC” Diagnostic link connector.
The obd2 plug is found under the steering wheel. The plastic body should be unclipped from its holder and cut from the Mondeo with as much wire as can be pulled free.
The tape covering the wires can be removed.
You will be left with This.
The pin’s are numbered as below.
Not all pins are used.
Pin out’s of the Dlc plug, these go to your harness plug.
2) To pin 16 (grey) on ecu plug.
4) To earth (Chassis).
5) To earth (chassis).
7) To pin 13 (white/blue) on ecu plug.
10) To pin 15 (blue) on ecu plug.
16) To switched 12v fuse box.
Pats indicator. This is the led that is usually found in the clock of the Mondeo. Its job is to show you the status of the immobilizer. Ford’s Passive Anti- Theft- System ( PATS )
Just one Pin from the ecu plug, No 42 (black/blue). This is a switched earth. Take one Led, colour of your choice. You need one that is pre wired with a resistor. This is mounted in your dash. The negative or black wire is connected to pin 42 of the ecu plug and the red or positive wire is connected to the permanent live.
The Immobilizer.
The picture below shows the transceiver or aerial. This is found behind the steering cowl. The ring sit’s around the ignition switch and is held to the steering column with one screw.
This is the wiring plug.
It needs cutting from the car with as much wire as can be pulled free.
Retaining clip shown at the bottom.
There are four pins, They may be colour coded as above or they may be all black as shown in the photo. This depends on the age of the donor.
Pin 3 to pin 19 grey/orange -- Pats TX signal.
Pin 4 to pin 53 white/green -- Pats RX signal.
Pin 2 is the earth, to chassis.
Pin 1 is a switched 12v.
All four wires will need extending from the harness plug up to the steering column.
Fuel pump relay.
The Ecu, both controls and monitors the fuel pump via a relay.
There are two pins from the ecu plug.
Pin 54 (black/blue) from ecu plug, Fuel pump relay control switched earth.
Pin 40 (violet/black) from ecu plug, fuel pump monitor.
Starter motor inhibitor relay. This stops the engine from cranking as part of the immobilizer.
Pin 27 (black/yellow) ecu plug -- starter motor relay control (switched earth).
Hope this helps any one wanting to run a zetec without spending shed loads. Its no harder than making a loom for a MS ecu. There is no mapping and the ecu can be had for a few quid.
ps it would be nice if it was made a sticky.
[Edited on 26/3/13 by big_wasa]
big_wasa
posted on 5/10/16 at 04:14 PM Reply With Quote
If you have the wiring loom your best bet is to compare it to my notes.
It's a good bet if it's from a car with a manual gearbox.
[Edited on 5/10/16 by big_wasa]
jambojeef
posted on 5/10/16 at 07:05 PM Reply With Quote
Just a quick note to say thank so much to Big Wasa - this work has been completely invaluable when wiring up the ST engine in my Westie - I simply could not have done it without the info you've posted so cheers!
Geoff
big_wasa
posted on 5/10/16 at 07:58 PM Reply With Quote
Thankyou, turbo Zetec and 3.0 v6 st220 coming soon.
big_wasa
posted on 6/10/16 at 06:12 PM Reply With Quote
posted on 6/10/16 at 11:27 PM Reply With Quote
What's your plan for the v6... more head scratching to run it on the bench???
big_wasa
posted on 7/10/16 at 07:14 AM Reply With Quote
I've always wanted one. There aren't many 2000> domestic U.K. Petrol Engines bigger than the st220 3.0 v6.
It was local and at a pocket money price but I must finish the Zt first....
Zetecsierra
posted on 12/10/16 at 06:30 PM Reply With Quote
Right ive done the above pinout on my ecu and it won't start. Ive got the pats led flashing all the time and just turns over so i have code read it today and got the following
1.) p1000 not all obd11 complete
2.) p0230 fuel pump circuit malfunction
3.) p1633 keep alive power too low
4.) b1600 passive anti theft system key transponder signal not receved
Any help would be a life saver
Thanks.. Nick
Zetecsierra
posted on 12/10/16 at 06:31 PM Reply With Quote
Thanks.. Nick
big_wasa
posted on 12/10/16 at 07:04 PM Reply With Quote
So the Laan is from a 2.0 Blacktop Mondeo or Cougar.
Is this a manual or auto car ? I am guessing manual ? It needs to be a manual.
To start with your not turning the Immobilizer of. If you have triggered it you may need to disconnect the battery to reset the ecu before trying again.
Did you get the key WITH the ecu ? Answer needs to be yes.
Did the wiring loom come from the same car ? Not essential but it cuts out the guess work if you havnt done one before.
Where did the pats tranciever come from ? Silvertop and Blacktop are differant.
To check the pats you only need a few wires.
Two switched live 12v. One permanent live 12v and four earths. The aerial needs a switched live 12v and the Pats led needs a permanent 12v live.
PIN numbers are for a fiesta but the pictures may help.
[Edited on 12/10/16 by big_wasa]
big_wasa
posted on 12/10/16 at 07:10 PM Reply With Quote
And this vid may help see what it should do.
Zetecsierra
posted on 12/10/16 at 07:13 PM Reply With Quote
Yes all the components are from the same car. This maye seam a daft question and i feel daft asking but what is the difference between a switched 12v and normal 12v also what the difference between earth and switched earth
Thanks for helping me
big_wasa
posted on 12/10/16 at 07:17 PM Reply With Quote
Permant live.
This is to power anything needing power when the ignition switch is of. I.e. Clock and ecu memory.
Switched live.
This is anything powered up by turning the ignition switch to run.
Again if the ecu is switching a circuit on or of it is nearly always done by switching the earh side and not the live.
I.e. The pats led has a 12v to one leg and the ecu controls it by switching the earh.
Talking of Led, what are you using for the led ? Not a flashing led is it ?
Zetecsierra
posted on 12/10/16 at 07:38 PM Reply With Quote
Right i get that now thats what i thought but thought id double check..
Just dug the recept out and it says. Flashing alarm LED.. Is this my problem? it was from maplin and was the only led they sold with a resistor in it and i seen alarm and thought it must be right
big_wasa
posted on 12/10/16 at 07:44 PM Reply With Quote
To check just put it on a battery. If it flashes it's not the right one.
Zetecsierra
posted on 12/10/16 at 08:02 PM Reply With Quote
Right ive been out and disconnected the LED from the loom and put it on a battery ive got in the house and it just flashes so this must be the problem. Is it only sending a signal to the ecu when the bulb is eliminated?
posted on 12/10/16 at 10:47 PM Reply With Quote
Positive to one side of the led and the other to the ecu which acts as the earth to turn it on and off when it wants.
A flashing led will disrupt the earth path and confuse the ecu into thinking theres a power interruption.
[Edited on 12/10/16 by coozer]
Zetecsierra
posted on 13/10/16 at 08:43 AM Reply With Quote
What resistor needs to be in the bulb and on the positave or negative
big_wasa
posted on 13/10/16 at 06:41 PM Reply With Quote
An average RED led running at around 20mA and a supply voltage of 13v will need a 1/4w resistor of around 680 ohm and put in the positive side.
[Edited on 13/10/16 by big_wasa]
<<  3    4    5    6    7    8    9  >>
