Author: Subject: Compression ratio v revs
borg230rover
posted on 1/4/13 at 08:21 PM Reply With Quote
Hi
Something has been troubling me, I have an R1 turbo kit, when the car had the Standard R1 (non turbo) engine it used to rev up to 11,750rpm now I have fitted the turbo it will only rev up to around 10,000rpm, the compression ratio has been dropped does anyone know if by lowering the compression ratio will it affect the maximum engine rpm.
Just remember "There is always going to be someone quicker than you"
mark chandler
posted on 1/4/13 at 08:36 PM Reply With Quote
Turbo will not affect the rev limit unless you have an undersized turbo or restrictive exhaust.
Sounds like your fueling is out, have you just blown a carbed engine ? Your fuel pump or float needles may not be up to the job.
Suggest you get it on a rolling road, when I was playing with mine it had issues and went to fast to log.
Regards Mark (just down the road)
BaileyPerformance
posted on 2/4/13 at 08:31 AM Reply With Quote
Originally posted by borg230rover
Hi
Check fuelling and timing first, we have see high rpm miss fire on turbo engines in the past, close your plug gaps to 0.6mm, you should also be running 10s.
