Author: Subject: how to reduce wiper motor speed?
xico_ze54
posted on 11/4/13 at 04:07 PM Reply With Quote
hi
this is for the electricity specialists...
I want to reduce a Sierra wiper motor speed to apply in a kind of giant toy with rotating parts. better explained: I want it to move very slowly.
how to make it without spend much money? and is it possible aplly the transformation in the lower speed and also in the intermitent speed?
thanks in advance.
Amadeu
[Edited on 11/4/13 by xico_ze54]
http://www.viseudesign.com/Sevenesque-36.htm
Bluemoon
posted on 11/4/13 at 04:25 PM Reply With Quote
Originally posted by xico_ze54
hi
thanks in advance.
Amadeu
You could try a PWM motor controller.
somthing like this
6V-90V 15A 0% -100% Pulse Width Modulation PWM DC Motor Speed Controller Switch | eBay
You will find a limit to how slow the motor will run before stalling.
Also the wiper motor takes quite a lot of current (no idea how much but it will probably be >8A, you should check this with a DVM) this make sure the PWM controller has sufficient current rating.
[Edited on 11/4/13 by Bluemoon]
xico_ze54
posted on 11/4/13 at 04:49 PM Reply With Quote
hi
thanks in advance.
Amadeu
somthing like this
thanks my friend.
and fot the intermitent speed I presume I have to attach the switch arm control. is that correct? or the wiper motor can operate intermitent speed without the switch arm?
cheers
Bluemoon
posted on 11/4/13 at 04:57 PM Reply With Quote
Not sure depends how it works... I think there is a a special relay on the sierra loom you would need to feed the motor controller from this I guess; not sure..
theconrodkid
posted on 11/4/13 at 07:28 PM Reply With Quote
there is a timer in the relay for intermitant and 2 sets of brushes in the motor for speed,you would be better off using one from a fiat with single wiper arm or an old lucas/mini cable type
who cares who wins
pass the pork pies
