Author: Subject: Pinto engine
floaty
posted on 12/4/13 at 06:52 AM Reply With Quote
Pinto engine
Has anyone got the specs for tappet and points gap on a standard pinto engine please. Cheers Floaty
garyo
posted on 12/4/13 at 07:37 AM Reply With Quote
I can do you a scan of the haynes data pages later tonight if you don't get an answer by then...
Macbeast
posted on 12/4/13 at 07:47 AM Reply With Quote
If you mean spark plug gap - 0.8mm
I think all distributors were inductive so no contact breaker points.
Valves - inlet : 0.2 +- 0.03 mm
- exhaust: 0.25 +- 0.03 mm
posted on 12/4/13 at 09:07 AM Reply With Quote
Ford/Fomoco/Autolite distributer (one with black cap) points 0.023" to 0.027" -- always set at wide end of range and recheck after 15 minutes running as gap tends to close up.
Bosch distributer (red/brown cap) 0.015"
DRC INDY 7
posted on 12/4/13 at 12:21 PM Reply With Quote
Points distributors need setting up between 48 to 52 degrees dwell angle
Puddle Dodgers Club
