Author: Subject: Tight squeeze for a silicone hose.... Will it be a problem?
Sloan85
posted on 14/4/13 at 07:52 PM Reply With Quote
I laid out the silicone hoses to see where they will be going today and there is one area that concerns me.
The connection to the water pump is very close to the gear shift bracket and the oil cooler pipe. The hose fits but as can be seen in the pictures it is tight. Will this cause problems? Will the hose wear out? If it is I could possible replace this small section with alloy tube or cut a length of alloy tube open and protect the outside of the silicone with it?
In hindsight I probably shouldn't have cut the GSXR oil cooler pipe so short before getting new unions crimped on but its done now.
Any suggestions?
Cheers!
Davegtst
posted on 14/4/13 at 07:58 PM Reply With Quote
I wouldn't want it there, it will chafe. Best move it.
steve m
posted on 14/4/13 at 08:19 PM Reply With Quote
Agreed, it will end up chaffing, and leaking, at just the time you did not want
Could you have a solid (metal) pipe to extend it out of the offending area ?
steve
Sloan85
posted on 14/4/13 at 08:30 PM Reply With Quote
I could try and get through the tight bit with alloy tube but even that may be tight. Ill give that a go tomorrow.
If the alloy tube is touching the gearshift bracket, would that be an issue too?
http://mkindygsxr.blogspot.co.uk
sdh2903
posted on 14/4/13 at 08:37 PM Reply With Quote
Yes it would, you don't want anything touching anything, eventually even the alloy would chafe through.
perksy
posted on 14/4/13 at 09:09 PM Reply With Quote
Its wear through like that sadly
You need a decent gap all the way around hoses & alloy pipes to allow for vibration & movement etc
Sloan85
posted on 14/4/13 at 10:10 PM Reply With Quote
Im really struggling with space if both alloy and silicone cant be touching anything. Photos below show the space available.
The only thing I can think of at the minute is to bend the gear linkage bracket down 20-30mm I could do this by cutting a wedge out the stiffener web next to the chassis rail, bending the bracket down and re-welding it. Obviously this would make a mess of the powdercoating though.
Any other suggestions?
Cheers!
inkafone
posted on 14/4/13 at 11:32 PM Reply With Quote
Can you fit a reducer (say 50mm to 40mm) at the pump end to a metal pipe with a lug welded on to take a solid rubber bobbin (exhaust type) and then back to original size for remainder of hose. The gear change bracket looks like it can be trimmed back a bit to allow more room. All movement/vibration - rad to metal pipe - will be taken on the hose.
40inches
posted on 15/4/13 at 07:15 AM Reply With Quote
Can you get a silicon elbow in there? I take it the hose is 25mm bore?
Tiger Super Six
posted on 15/4/13 at 09:05 AM Reply With Quote
Can you get an off cut and cut it down it's length and then put it round that piece of pipe and cable tie it in place. That way it will wear on the offcut and as long as you keep an eye on it you can just replace that as and when, then it will never get through to the actual pipe?
Not ideal, but could see you through.
Mark
Tiger Avon
posted on 15/4/13 at 10:25 AM Reply With Quote
It's not the "touching" that's the problem, it's any relative movement/vibration between parts that will cause damage to the pipe. You should be able to make up some brackets/clips to hold a silicone or alloy pipe away from danger.
Sloan85
posted on 16/4/13 at 10:08 AM Reply With Quote
Going to have to cut the end of the bracket and make up a new one to move the gear shift cable further towards the bulkhead by about 60mm
Photo below shows where silicone elbow will be positioned in relation to the new position of the gear shift cable. It will also line up the cable better than it is at present.
How should I protect the steel when I cut the end off? What paint is best to use?
