Author: Subject: Anyone made their own suspension bushes?
b14wrc
posted on 15/4/13 at 07:19 PM Reply With Quote
Hi
Any one made their own suspension bushes??
Here are my prototypes:
The mould is very crude and needs more work if I'm going to more on to actual bushes for the car:
However, finished mock up actually seems quite good!
This test bush is made in very hard (and brittle) PU resin, Shore hardness D70. Now, I know this is not the right material, I'm looking at starting with a PU rubber in the A65 range, does this seem reasonable?
The best thing with making my own is 1. Saves me a lot of cash! 2. My tube dia is larger than the book and the tube was also cheaper and 3. I can have different bush hardnesses on different components, ie easier to alter if it isn't right first time.
Anyone done similar??
Rob
[Edited on 15/4/13 by b14wrc]
20vt powered rear engined locost
steve m
posted on 15/4/13 at 07:35 PM Reply With Quote
I have to add, that if i had a lathe, and the skill to use it I WOULD !!
dave r
posted on 15/4/13 at 07:59 PM Reply With Quote
i machined my own
was very hit and miss size wise as the material grabbed and did not machine well
they have however lasted 3 years so far ;-)
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
mark chandler
posted on 15/4/13 at 08:46 PM Reply With Quote
I made some bushes to fit the original mountings on my blade engine by buying some cheap land rover bushes and spinning up in my lathe, high speed and sharp tool worked for me
designer
posted on 15/4/13 at 08:50 PM Reply With Quote
Most 'plastic' machine better if they are kept in the deep freeze.
b14wrc
posted on 15/4/13 at 09:12 PM Reply With Quote
Yes you will find that with Polyurethane rubber. Hence why I'm casting it.
What harnesses did you guys use?? Just wanted a starting point grade really.
I don't have a lathe but prefer moulding anyway as my background is composites.
Rob
trextr7monkey
posted on 15/4/13 at 10:23 PM Reply With Quote
Rob I bought some 50 mm nylon to have a go with some time, was thinking more of steering column type bushes but never happened yet, got 3 lathes in sunny Carlisle, give us a shout if you fancy some turned ones.
atb
Mike
Bluemoon
posted on 16/4/13 at 01:35 AM Reply With Quote
I seem to recall a thread were someone had moulded there own bushes. Mold could make many at once. Might be worth a good search...
trikerneil
posted on 16/4/13 at 05:15 AM Reply With Quote
Possibly THIS thread?
HTH
Neil
ACE Cafe - Just say No.
Bluemoon
posted on 16/4/13 at 09:39 AM Reply With Quote
HTH
Neil
Thats the one..
Alan B
posted on 3/8/13 at 01:33 AM Reply With Quote
yeah...I know that guy...LOL
Talon Motorsport
posted on 3/8/13 at 08:58 AM Reply With Quote
I looked in to doing this myself untill I found that you can buy them for 47 pence each from Wisbech engineering in all the colours of the rainbow.
b14wrc
posted on 4/8/13 at 10:51 AM Reply With Quote
Morning,
Just looked on the Wisbech price list for 2012, and yes if you buy 101 of these they cost £0.47 each, but it does not specify the dimensions and the crush tube that goes with them are £5.00, so that will soon add up.....
I'm happy doing it myself, the learning I have had in making my own has been fun.
Rob
Scuzzle
posted on 4/8/13 at 11:24 AM Reply With Quote
I made my own engine mountings out of a polyurethane kit, turned out OK.
Used this kit
Stripped out the existing rubber which was all torn
ANd this was the finished item
Once completed I sprayed black plasti-dip over the bare metal and ended up with home made poly mounts. Engine mounts you can buy in poly but this is the gearbox mount that nobody makes in poly so it should be unique.
[Edited on 4/8/13 by Scuzzle]
b14wrc
posted on 14/9/13 at 08:29 AM Reply With Quote
Hi all,
Well I'm just about done with the bushes I reckon.
Here is my final mould and the first of the bushes, only thing I need to do is vac the final bushes prior to casting:
They have turned out ok!might find I need harder rubber later, but we will see when it's all put together.
Rob
