Author: Subject: Opened the engine
jacko9370
posted on 16/4/13 at 07:31 PM Reply With Quote
Opened the engine
Am changing from a pinto to duratec engine.
Got engine from scrappies and about to change head as aquired a new head with uprated cams and springs etc.
Taking the head off, the top of the pistons dont look in great condition, I suspect its just from where engine has been sat with nothing happening with it for a while?
Havent tried turning by hand as didnt want to cause any damage to the bore
Hopefully pic will give you some idea, will try get better pics if needed.
Anyone advice/thoughts appreciated
ReMan
posted on 16/4/13 at 08:06 PM Reply With Quote
If turning by hand causes damage, I suspect its already knackered?
Did you get some mleage proof from the scrappy?
[Edited on 16/4/13 by ReMan]
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jacko9370
posted on 16/4/13 at 08:08 PM Reply With Quote
Ive got what he said the mileage was written down on paper
Dont know if it is too bad, might just be superficial and fine
ReMan
posted on 16/4/13 at 08:18 PM Reply With Quote
Put a picture up
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jacko9370
posted on 16/4/13 at 08:19 PM Reply With Quote
Weird, I did out pic on original post not sure why not there will try ahain
jacko9370
posted on 16/4/13 at 08:20 PM Reply With Quote
ReMan
posted on 16/4/13 at 08:27 PM Reply With Quote
Looks like normal coking to me, perhaps a bit black/oily.
Presumably as cheap as they are its worth just running it.
Oil the bores let it soak for a while and then spin it over.
Scrape the tops clean, put your head on and run it
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jacko9370
posted on 16/4/13 at 08:29 PM Reply With Quote
ReMan
posted on 16/4/13 at 08:39 PM Reply With Quote
Wot no replys from anyone with a CEC??
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
Not Anumber
posted on 16/4/13 at 10:15 PM Reply With Quote
you always knew where you were with a pinto.
redeye
posted on 16/4/13 at 10:29 PM Reply With Quote
Looks exactly like my duratec did when I took it apart....just normal coking as already mentioned, cleaned it up and its all good
Took the head to a machine shop and had it cleaned up and lightly polished too.
You wont regret going from Pinto to Duratec.
40inches
posted on 17/4/13 at 07:30 AM Reply With Quote
Duratec? Wot bike's that off then?
Daddylonglegs
posted on 17/4/13 at 09:36 AM Reply With Quote
In my case, at the back usually
Maybe if I get to fit my ZX9 carbs I'll be nearer the middle?
[Edited on 17/4/13 by Daddylonglegs]
jacko9370
posted on 17/4/13 at 08:46 PM Reply With Quote
Putting the new head on does anyone recommend using a sealant as well as gaskets or just the gaskets?
ReMan
posted on 17/4/13 at 09:52 PM Reply With Quote
I'd sauy gasket only on that engine.
But what do I know i've got a BEC
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
pjay
posted on 17/4/13 at 10:03 PM Reply With Quote
Piston crowns look fine - not much carbon build up at all.
Use just a little bit of sealant at the front of the block where timing chain cover meets the small gap between the head and the block (not much at all just so it oozes out a bit).
Looks like the block has corroded quite a bit - use GT85 sprayed over the aluminium block etc and left to dry (not down the bores though).
Is it hi port head you're looking to fit?
Good change from Pint to Dura!
