JeffHs
posted on 19/4/13 at 12:12 PM |
Rolled rings?
Is there anyone on here who can make me some rolled rings? I want 2 10 inch diameter by 2 inches wide and 3 x 5 inch diameter 3/4 inch wide.
Both sizes in thickest gauge poss up to 1/2 inch.
They're for the front and rear wheels and flywheel for a model traction engine.
liam.mccaffrey
posted on 19/4/13 at 12:38 PM |
how critical are your OD's?
10" NPS, Sch 60 pipe is 10.75" OD and 12.7mm wall? Might be easier to get
4.5" NPS, is 5" OD -Sch XS is 9mm wall XXS is 18mm. 4.5" not a common size though
Build Blog
Build Photo Album
Matt_C
posted on 19/4/13 at 02:41 PM |
Hi Jeff,
There are a few of the suppliers we use for work who do rolling. I don't know about cost but I can enquire if you want?
With those sort of diameters I am not sure how close to 1/2 thickness you will be able to get, I would think you would struggle to get over 8mm for
the larger and possibly 5mm for the smaller one, but that is just a guess.
Volvorsport
posted on 19/4/13 at 03:49 PM |
doubt youll get something like that rolled in that thickness..........
www.dbsmotorsport.co.uk
getting dirty under a bus
Grimsdale
posted on 21/4/13 at 12:20 PM |
what's your budget? i deal with a manufacturer of forged rings and another that makes cast rings. Will not be cheap, or even reasonably priced.
JeffHs
posted on 21/4/13 at 02:14 PM |
Thanks guys. I'm coming to the conclusion that this will cost more than my car! I've found a source for 5 inch pipe at 6.80 per inch!
Copper tube for the boiler 60 quid, etc. I'm staggered by the cost of metal. Think I'll stick with wood turning
richardm6994
posted on 21/4/13 at 02:21 PM |
1/2 inch thick? That's a bit ott? My 4 inch scale garret is about 3/8 thick from memory and I rolled / welded myself.
What you building? By the size of the wheels I'm guessing its about 2 inch scale? Somewhere I've still got he rollers I used to do my
wheels so I'll see what I can do. Have you got the metal?
br />
[Edited on 21/4/13 by richardm6994]
richardm6994
posted on 21/4/13 at 02:37 PM |
Any wouldn't you be better using a casting for the flywheel?
