Author: Subject: C20XE Wiring in a kit car -Coil connection
mcg
posted on 22/4/13 at 11:56 AM Reply With Quote
Just need to check where I connect the ring terminal in the picture?
- The guy that removed the engine from the Corsa, left the nut loose as pictured, which makes me think that this is where the ring terminal should go.
- A wiring diagram I got from the migweb forum (you can see it in the picture) indicates that this terminal should go to a 12v ignition live source.
The reason I am not sure is the + side of the coil is on the other side. (I am probably mis-understanding!)
Can you please confirm that this is all ok?
Thanks in advance.
Matt
