jossey
posted on 5/5/13 at 07:28 AM |
893 wiring diagram n workshop manual needed
Can anyone help.
I have just bought a 893 n 919 fireblade engine and could do with some help fitting n wiring up.
Has anyone got the wiring diagram or workshop manual as a PDF please.
David Johnson
rgrs
posted on 5/5/13 at 08:47 AM |
Have sent you a e-mail with the 893 RR wiring diagram,
However it only need a few wires.
ECU Wiring.
Yellow/green-----------Tachometer
Dark Green-------------Earth
Dark Green/White----Clutch Switch/Side stand(short to Earth)
Yellow-------------------Pulse Generator
Light Green------------Neutral Switch (short to earth)
White/Yellow----------Pulse Generator
Yellow/Blue------------Coil Cylinders 1 & 4
Blue/Yellow------------Coil Cylinders 2 & 3
Black/White-----------+ve
That's It
Roger
jossey
posted on 5/5/13 at 11:04 AM |
Cheers roger.
Thanks for taking time to reply.
David Johnson
