Author: Subject: C20XE / Red Top Connector ID Question
mcg
posted on 8/5/13 at 11:53 AM Reply With Quote
Hi - Just trying to identify what this connector is for? Installing a c20xe into my F27. I cant see what it should be connected to, and there was no tube in the stuff I got when I bought it. Is it just a vent or overflow or take off?? Any advice would be great.
[img][/img]
silky16v
posted on 8/5/13 at 12:01 PM Reply With Quote
Carbon canister purge valve, just leave it connected if running oem ecu if running aftermarket just remove
mcg
posted on 8/5/13 at 12:22 PM Reply With Quote
Thanks. There was nothing attached to the connector highlighted - so is it ok to leave open like that?
silky16v
posted on 8/5/13 at 05:35 PM Reply With Quote
Just leave both pipes off and block any vacuum pipe going into the inlet
