Author: Subject: Which rad for a Haynes roadster???
Aaron_n_Sim
posted on 10/5/13 at 09:49 AM Reply With Quote
I was wondering which radiators are recommended for a Haynes Roadster.
Aaron
Thailoz
posted on 10/5/13 at 10:24 AM Reply With Quote
I think they are using VW polo radiators check the haynes roadster forum for the exact mk engine size etc.
It may sound a dumb Question to you but to others it may be an eureka moment
Aaron_n_Sim
posted on 10/5/13 at 10:27 AM Reply With Quote
Yeah I think you're right the book says Polo, Clio, or similar! I was hoping for peoples ideas based on experience.
Aaron
Ben_Copeland
posted on 10/5/13 at 10:42 AM Reply With Quote
Yep the smaller of the vw polo radiators, about £30 new on ebay
Ben
Locost Map on Google Maps
Enter Your Details Here
Aaron_n_Sim
posted on 10/5/13 at 10:45 AM Reply With Quote
Thanks that's what I was going to go with, seen them on eBay! They're about 400mm wide? Does that sound about right?
Aaron
Ben_Copeland
posted on 10/5/13 at 10:48 AM Reply With Quote
Yeah think its a 1litre polo one. 400mm rings a bell
Ben
Aaron_n_Sim
posted on 10/5/13 at 10:50 AM Reply With Quote
Thanks Ben much appreciated
Aaron
davidimurray
posted on 10/5/13 at 10:53 AM Reply With Quote
I used a Clio one which is a bit bigger and fills the nose a bit more. Have a look at the photos in my galleries.
Dave
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
Aaron_n_Sim
posted on 10/5/13 at 11:27 AM Reply With Quote
Dave
That's a comprehensive diary! Thanks, what year and engine size was the Clio?
Aaron
davidimurray
posted on 10/5/13 at 11:43 AM Reply With Quote
I tried to take photos of all the bits I couldn't find photos of elsewhere!
I think it is a Mk1 but can't remember which engine size. Might have some info at home. The only tricky part is getting the 45 degree hose at the bottom out and past the frame rails, it is very tight but is possible.
Dave
Dave
Aaron
Aaron_n_Sim
posted on 10/5/13 at 11:47 AM Reply With Quote
Dave
Dave
Aaron
Thanks Dave,
That's no problem for me, I'm used to squeezing a large hose through a tight hole
Aaron
Dualist
posted on 10/5/13 at 06:28 PM Reply With Quote
You can fit a Merc 190 rad but I can't remember what version.
Edit...
http://www.haynes.co.uk/forums/showthread.php?t=12530&highlight=merc
[Edited on 10/5/13 by Dualist]
Rotary build coming soon...
Originally posted by RichardK
I recently discovered that pigs can p i s s sideways when being transported
Aaron_n_Sim
posted on 10/5/13 at 06:32 PM Reply With Quote
Ok thanks for that, out of curiosity will you be using a wankel, not being personal or anything!
Aaron
Work to Live don't Live to Work
Dualist
posted on 10/5/13 at 06:37 PM Reply With Quote
he he, yes I am and the buggers get hot, so the bigger merc rad is what I'll be using.
Started my build but not posted on here but the Haynes forum.
Aaron_n_Sim
posted on 10/5/13 at 06:52 PM Reply With Quote
Have you thought about a waterless coolant system -40 to 180 degree so in this country it'll never freeze or overheat!! You can find it on eBay Adams waterless prep fluid and waterless coolant it's £100 for the pair both 5 litre bottles and has infinite lifespan you drain it through a coffee filter or similar into a clean container when you need to, you just keep on reusing it!
Good luck with your build!
Aaron
b14wrc
posted on 3/6/13 at 11:30 AM Reply With Quote
I have just ordered a Honda Civic Alloy Radiator for my mid engined locost.
One consideration i made was sizing the new rad to the original one. Has anyone considered the engines they are using to the smaller Polo or Cilo Radiators? What i mean is, is it improtant to get a rad of equal capacity to the original donor car? My Fiat Coupe rad would not fit the nose of my locost so had to look at alternatives.....
In my car, i will be carrying a lot more coolant than the standard donor, so probaly could afford a small decrease in rad capacity.... however, i have tried to find a rad that is almost the same size. I do intend running more power than the engine originally produced, so more cooling will be a requirement.
Will let you know what i think of the Honda rad, believe this is a common option in America....
Rob
20vt powered rear engined locost
