Author: Subject: Brake res hose - anybody got a certificate?
birdii
posted on 10/5/13 at 10:07 AM Reply With Quote
I bought some brake reservoir hose from Rally Design at stoneleigh. Unfortunately they didnt have any certificates with the but they promised to email me one.
To my surprise they actually have emailed me a cert but its for a different hose so not much use! I have been back in touch but no answer.
So, does anybody have a copy of the spec for Cohline 2337 hose? The hose is very clearly marked with the type and material (EPDM) which is correct for brake fluid.
Hopefully easily resolved!
I've tried google to no avail.
40inches
posted on 10/5/13 at 11:29 AM Reply With Quote
You will not find any specs for that hose because Cohline manufactured it for VAG. The Cohline catalogue number for Brake fluid fill hose is 2322. Thats the bad news
The good news is, CBS sell the 2337 VAG hose, and I have a spec sheet for it
U2U your email, and I will send you a copy.
birdii
posted on 10/5/13 at 11:45 AM Reply With Quote
Cant' believe it, 10 minutes after posting i get an email from Rally Design with all the info i need!
I should have more faith!
Thanks for the offer of help anyway!
regards
Dan
theprisioner
posted on 10/5/13 at 03:31 PM Reply With Quote
I read this thread and I had no knowledge about this type of hose so I phoned RD immediately and got the last bit, 750mm of 3/8" hose in stock (no doubt they have it on order). They are posting a certificate. Thanks chaps IVA date looming.
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
