Author: Subject: megajolt or similar for crossflow or best place to source
Leyther
posted on 12/5/13 at 09:03 PM Reply With Quote
I am thinking of changing from dizzie to a megajolt or similar for my crossflow with bike carbs.
Has anyone got anything or advise on best place to source the stuff.
Dave
AdrianH
posted on 12/5/13 at 09:14 PM Reply With Quote
Would you want to go TPS or MAP, I guess TPS with bike carbs. Is it a trial you wish to do?
Only asking as I have an unit sat on my selves, I bought it some time ago the plan is to replace the Esc-hybrid unit on my CVH but have not done it yet and probably will not for a while. If you wish to borrow it and see if the jolt is your way to go then you may do so.
I have edis coil pack and a VR sensor, you would need your own 36 tooth wheel. plug leads etc
It is a Megajolt Lite Jnr. bought of here over a year ago. Think it is up to version 3. summat firmware.
ADrian
Why do I have to make the tools to finish the job? More time then money.
mikeb
posted on 13/5/13 at 10:14 AM Reply With Quote
megajolt or NoDiz seems to be the options.
I spent a bit more on the NoDiz unit, doesn't need an edis4 unit and connects via bluetooth and has as funky app for your smart phone, its a bit more money though.
[Edited on 13/5/13 by mikeb]
J222jra
posted on 14/5/13 at 03:16 PM Reply With Quote
Im looking at doing the same thing ang getting rid od the distributor.
What benefits are their of mega jolt and is it possible to buy a full kit of everything i need to convert my 1600 xflow?
redturner
Senior Builder
Posts 449
Registered 9/11/12
Member Is Offline
Photo Archive Go!
Building: Run 2 ltr Black Top in single seater race car.
posted on 14/5/13 at 07:03 PM Reply With Quote
I use Megajolt, supplied by Trigger Wheels in conjunction R1 carbs on my Zetec and it runs brilliant. You should not have a problem with a 1600 x-flow. I used a Danst manifold.
