Author: Subject: dash 2 help please
daniel mason
posted on 13/5/13 at 08:38 PM Reply With Quote
dash 2 help please
since buying the fury i have notice that the etb digi dash2 appears to be doing something strange!
one i turn the ignition on the correct data appears on the screen. oil press,oil temps,water temps and rpm. but after the engine has been running a while the letters DAT appear on the screen and all parameters dissapear, and correct data will not re-appear unless i turn off engine and re start! any ideas?
loggyboy
posted on 13/5/13 at 09:01 PM Reply With Quote
Dat is displayed when its connected to a pc. Check the serial port incase its shorting, damp or similar?
Mistral Motorsport
mr T
posted on 13/5/13 at 09:11 PM Reply With Quote
is it recording data you can turn it of by holding button a down for 2 seconds
tony
daniel mason
posted on 13/5/13 at 09:22 PM Reply With Quote
i tried holding each button and got nothing. pushed both and it entered menu settings! there is a data logger in the system though
loggyboy
posted on 13/5/13 at 09:31 PM Reply With Quote
Disconnect the logger as the fault maybe in that.
Mistral Motorsport
