Shorty
posted on 16/5/13 at 06:48 PM |
How many bolts? Zetec to type 9
I posted this on the Haynes forum but since it's not specific to roadster and I guess there are going to be a lot of people here with zetec-type
9, I thought I would post here too.
Just bolted my 1.8 focus zetec engine to type 9 gearbox and I only have 5 bolt holes that line up. Is that correct?
Not sure if I need a completely different sump but I was expecting at least one to fit underneath. There's 2 at top, 2 exhaust side(above where
starter will be) and 1 on inlet side.
Oh and I'm guessing the red line I have marked is going to be approximately how much needs removing for the starter motor.
Any comments/ advice welcome
[Edited on 16/5/13 by Shorty]
posted on 16/5/13 at 06:52 PM |
Yes, the 5 bolts is fine, heres my sump mods for the starter.
I chopped the bottom up flush with the bottom of the bellhousing.
Shorty
posted on 16/5/13 at 06:57 PM |
Wow. That was fast.
Thanks, that has settled my mind, I was thinking everything was wrong. engine, bell housing, sump.
Oh, and do I need a spacer between the two?
lewis
posted on 16/5/13 at 07:14 PM |
Same as above will be fine like that & how mine is
I am a driving god!..........sort of
Shorty
posted on 16/5/13 at 07:22 PM |
I'm also in need of a starter if anyone has one that they don't want.
big_wasa
posted on 16/5/13 at 07:40 PM |
Also yes just the five, Off-putting isn't it just five little bolts to hold them together.
Spacer, you want a dust/stone guard. You can cut one out of a sheet of steel or alloy.
There are lots of starters that can be made to fit, some easier than others.
[Edited on 16/5/13 by big_wasa]
Shorty
posted on 16/5/13 at 08:55 PM |
Yes it is off putting, very surprising but I guess its been proven.
Yes dust/ stone guard. I've seen the previous post you mad about retro ford doing them but I don't think they do them anymore. can only
see rs2000. Is there anyone else doing them?
If I do have to make one up, what sort of thickness should it be? I have the standard focus one and was very thin off the top of my head.
And easiest starter to fit? is it LRS707? I will keep a lookout for a 2nd hand for now for setting up but once happy will buy new.
big_wasa
posted on 16/5/13 at 09:05 PM |
Made mine out of 1.5 steel. That starter is the one most quoted as the one that will fit.
Shorty
posted on 16/5/13 at 09:16 PM |
Thanks again, great info.
tims31
posted on 16/5/13 at 10:41 PM |
Yep as above, this is my spacer, crud guard
here
Build: http://www.martinsfurybuild.co.uk/
