JeffJeffers
| posted on 18/5/13 at 11:34 AM |
Alternator parts
Few parts I no longer need after moving the location of my alternator.
I have a tiger alternator bracket for a Zetec. I had to drill an extra hole in one of the brackets to get it to fit the black top. It is used with a
LRA100 alternator.
£25 delivered
I have a LRA100 alternator which is only about 6 months old.
£30 delivered.
I also found another alternator. Not sure what it is from but if anyone can make use of it.
£20 delivered
wombat
| posted on 18/5/13 at 12:34 PM |
U2u sent
JeffJeffers
| posted on 22/5/13 at 10:20 AM |
Lucus alternator and bracket sold.
Magneti Marelli alternator still available.
loggyboy
| posted on 22/5/13 at 10:23 AM |
Out of interest, were the brackets designed for the alternator to go low down on the exhust side or high up on the intake side?
Mistral Motorsport
JeffJeffers
| posted on 23/5/13 at 10:29 AM |
This isn't a picture of my car but here is where it fits.
loggyboy
| posted on 23/5/13 at 11:41 AM |
Excellent pic, that is agood way to mount that pulley bracket, 1st ive seen like that, most try to bolt on to the side of the block.
Mistral Motorsport
gavin174
| posted on 23/5/13 at 02:33 PM |
if you make the two bolt holes into slotes....
you can use it to tension the belt.
loggyboy
| posted on 23/5/13 at 02:43 PM |
Certainly an option, but very little way of apply force to tension it unlike the leverage of sticking a bar behind the alternator gives!
Mistral Motorsport
emwmarine
| posted on 28/5/13 at 04:45 PM |
Great photo. Great solution.
What is the idler pulley from and where did you get it??
Building a Dax Rush.
JeffJeffers
| posted on 29/5/13 at 07:59 AM |
The pulley was off a Mercedes van. I have just had a quick look for the part number but can't find it.
Best thing to do is give Tiger a call.
