Author: Subject: Manifold Advice
T66
posted on 18/5/13 at 12:33 PM Reply With Quote
Manifold Advice
Been busy making an exhaust manifold, my plan is to use spring & eye retainers on the 4 pipes into the collector. Am I better off hard mounting the collector to the chassis, or arranging it on a rubber bobbin type thing ?
Do I need to soft mount all of the system on bobbins for the vibration etc ? exhaust virgin....
tomgregory2000
posted on 18/5/13 at 05:58 PM Reply With Quote
Can you hang the collector off the engine?
So manifold and collector move as one, is your engine hard mounted or on av mounts?
T66
posted on 18/5/13 at 06:24 PM Reply With Quote
Engine is hard mounted to the chassis
bi22le
posted on 18/5/13 at 10:22 PM Reply With Quote
Personally I would rubber mount everything to reduce vibration and reduce stress.
Please read my ring story:
unijacko67
posted on 18/5/13 at 10:57 PM Reply With Quote
Rubber mount engine and exhaust if possible for best results imho. Cheers
http://www.kittenkitcar.co.uk
40inches
posted on 19/5/13 at 10:33 AM Reply With Quote
Me too! Or fit a small flexy in the system.
T66
posted on 19/5/13 at 11:39 AM Reply With Quote
I thought of either a bobbin mounted to the chassis and then u clamped round the exit side of the collector, what I might do now is fit a flexi after the collector aswell as the bobbin.
cheers guys
[Edited on 19/5/13 by T66]
