<<  1    2  >>
Author: Subject: Audi V8 timing belt job
coyoteboy
posted on 24/5/13 at 12:10 PM Reply With Quote
So my donor engine needs a belt change (doesn't but it's worth doing now as I need to change the water pump). Tools for the job are ~£400 alone and basically comprise a bunch of locking devices to hold all 4 cams in place with the crank (cams have a single pulley and are linked at the opposite end with a chain so it's no more difficult than a 16v head in essence). I'm thinking I can do it the way I've done pretty much all of my cars - bodge a few locking tools together, matchmark the cams and crank locations, take care and rotate it by hand a few cycles to ensure it lines up.
Anyone any experience with the ABZ engine timing belt job that can highlight any potential issues?
loggyboy
posted on 24/5/13 at 12:18 PM Reply With Quote
These will be interference fit pulleys, meaning home made locking devices will need to be spot on, not just close enought to ensure it doesnt turn half a turn like you could in the old days when the pulleys were keyed to the cam/crank. We are talking less than a degrees accuracy required.
Even with 2 camshaft engines its easy to get wrong. I did 2 clio 172s a recently and you tentsion the belt fully, but keep the pulley bolts loose, so the position of the belt is irrelvent to the position of the cams/crank. then when the belts all tenstioned, you torque up the pulley bolts.
For something as complex as V8 you will need to get it right.
Mistral Motorsport
coyoteboy
posted on 24/5/13 at 12:29 PM Reply With Quote
Hmm it's just the crank pulley that I'll be taking off but I haven't checked if it's an friction fit type or keyed, I must admit. I will have to dig in more detail but I think the tools are a tool to lock the two cam pulleys together, a set to lock each pair of cams together (not really needed if the front set are locked but probably used for things like seal replacements if removing the front pulleys, so used in the standard procedure).
It's the crank that'll be an issue if not keyed then. I think the official crank locker is a tooth holder on the flywheel - not a problem to fab with the box off and no clutch fitted, but I hate keyless pulleys - they almost always take 2 attempts to get right IME!
Edit: Crank pulley is apparently keyed on the RS6 - slightly different engine but same era:
[Edited on 24/5/13 by coyoteboy]
loggyboy
posted on 24/5/13 at 01:15 PM Reply With Quote
Crank might be keyed but cams arent:
http://www.audipages.com/Tech_Articles/enginemechanical/tbreplace0.html
Mistral Motorsport
posted on 24/5/13 at 02:22 PM Reply With Quote
There is certainly a key on the pulley in the picture.
chrism
posted on 24/5/13 at 04:20 PM Reply With Quote
Would it not be easier/cheaper getting an Audi specialist to do it. If the engines out and you can take it to them, it would save a significant amount of labour cost as I believe most of the labour cost is removing everything to get access to the front of the engine and then putting it all back again.
May cost a fair amount less than just buying the tools for the fitting labour.
A little hard work never killed anyone, but why take the risk!
Simon
posted on 24/5/13 at 05:11 PM Reply With Quote
My thoughts exactly. Audi will probably be scheduled so even though you've 95% of the work, they'll still want 100%, but non franchised might come up with sensible price, plus if they screw it up, you've got some comeback.
Simon
coyoteboy
posted on 24/5/13 at 05:36 PM Reply With Quote
Can't easily transport it anywhere (no suitable vehicle) and I have no means of checking/correcting any job they do if they cock it up and I can't run the engine for 6 months, at which point I have no comeback. I never use garages, ever. Seen too many expensive botch jobs, I'd rather do a cheap botch job and only have myself to blame (never had a problem before, don't expect any with careful research).
Maybe if I could find a friendly specialist who would pop in on his way home and do it in my garage I might be tempted, but even so it's going to cost more than the engine is worth if I'm to offer them a fair return on their time.
Crank might be keyed but cams arent: http://www.audipages.com/Tech_Articles/enginemechanical/tbreplace0.html
I'll have to assess the belt pattern and tensioning but I think everything between the cams is static, so providing I don't remove any of the pulleys (there's no need to) I don't need to worry about anything - matchmarks and tooth counting will work fine as it always has.
navyseamonkey2011
posted on 24/5/13 at 07:02 PM Reply With Quote
Home made tools, tipex pen and check everything twice.
job done!! done let the naysayers on forums put you off!
Mark Allanson
posted on 24/5/13 at 07:18 PM Reply With Quote
Get a stanley knife, cut the belt longditudinaly while in position until it is completely split in two, slice the outer half and remove, feed the new belt onto the pulleys until it touches the old remaining inner half, then cut away the inner half and slide the new belt completely onto the pulleys.
froggy
posted on 24/5/13 at 07:25 PM Reply With Quote
Spring loaded dot punch and a spare pair of hands to keep the cams from moving while you nip the pulleys back up . I paint pen the pulleys etc then dot the cam with the punch near to a cap . The only issue is having enough hands to keep them from moving , only done one but as your engine is out you can lock the crank up so its not going to move .
[IMG]http://i144.photobucket.com/albums/r187/froggy_0[IMG]
stevegough
posted on 24/5/13 at 07:52 PM Reply With Quote
What a fantastically simple way! - the only pitfall I could forsee here is not being able to force the new belt onto the pulleys without de-tensioning first?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
40inches
posted on 24/5/13 at 07:54 PM Reply With Quote
Now that's something to remember for future reference.
40inches
posted on 24/5/13 at 08:00 PM Reply With Quote
Possibly hold the old belt in tension with an "in yer face" cable tie,pulling from across the other side of the engine, Mr Gough
Mark Allanson
posted on 24/5/13 at 08:03 PM Reply With Quote
It is sometimes a bit tight, but a very small amount of slackening of the tensioner(s), without allowing any movement of the belt on the pulley lobes, will go a very long way.
[Edited on 24/5/13 by Mark Allanson]
rdodger
posted on 24/5/13 at 08:07 PM Reply With Quote
Brilliant!
stevegough
posted on 24/5/13 at 08:25 PM Reply With Quote
Not finding yourself agreeing with me again, are you, yard-and-a-half?
Luego Locost C20XE.
coyoteboy
posted on 24/5/13 at 09:54 PM Reply With Quote
That's actually a genius method I like, but it's got the flaw of I can't change the water pump with it But I will remember that! I'm gonna go old-school folks, matchmarks, locked crank and tipex is the way forward, you've given me the (possibly false) confidence
froggy
posted on 24/5/13 at 10:10 PM Reply With Quote
If it's the same code as the one I did which I think was a 40v version you need to tension the belt with the cam pulleys floating . You can't set the tension between the two pulleys without moving them both if they are still locked to the cams
Mark Allanson
posted on 24/5/13 at 10:11 PM Reply With Quote
You can! just cable tie the old half a belt to each pulley, release the old water pump, install the new, check that nothing has moved, continue as described
posted on 24/5/13 at 10:52 PM Reply With Quote
MG XPAG and pre-ww2 Morris engines used marks on the chain which lined up marked teeth on the sprockets .
coyoteboy
posted on 25/5/13 at 01:52 AM Reply With Quote
It's not, it's the 32v version, but i still don't see the need to float the cam pulleys if they were set right the first time, it's just a like for like swap. Assuming a belt with the same number of teeth, tooth to tooth difference won't change and so relative timing wont change either.
froggy
posted on 25/5/13 at 06:42 AM Reply With Quote
Your abosolutely right and I'm going to work in a minute to throw all my locking kits in the bin . Your method will work but it won't be timed 100% . I use a firm that hire kits out for stuff like twin vanos bm s that I don't do regularly .
harvs
posted on 25/5/13 at 08:58 AM Reply With Quote
Hi
You should be able to get the new belt in the right position, but when you release the tensioner the relative position between crank and cams will shift slightly I think (maybe not as much as a whole tooth, but a little none the less). If the cams are floating this movement due to tensioning will happen before the cams are locked in position, so will be fine. But if the cams aren't loosened first, the timing will likely be a little out.
I've not experience of this (yet), so don't know how much of an issue the timing being out a little will be, but it's obviously not ideal.
froggy
posted on 25/5/13 at 09:09 AM Reply With Quote
It normally shows up as a slightly rough idle or throws up a crank /cam coherence code. Most common one I've seen is the Renault k4m series engines where people have done belts by paint marks then have issues with idle and stalling on light throttle .
On something with a very long run between the cams you can't get the tension between the two right
<<  1    2  >>
