New Topic New Reply
Author: Subject: Fitting rear arches - couple of questions??
Sloan85
posted on 24/5/13 at 06:39 PM Reply With Quote
Which way round to the rear arches go? One side seems more pointed at the bottom than the other.
Also, what should line up with what when fitting them? Should the bottom of the arch be at the bottom of the side panel at the front or is that too low?
Any side on photos would be helpful.
http://mkindygsxr.blogspot.co.uk
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
Building: Caterham R300, Caterham Roadsport,Indy R1,Indy Zet
posted on 24/5/13 at 07:43 PM Reply With Quote
Pointed towards the front... ask me how I know ??
40inches
posted on 24/5/13 at 07:45 PM Reply With Quote
I had the pointed end to the front, and lined up the ends of the arch with the bottom of the panel. Fitting a wheel helps to centralise the arch, front to back.
40inches
posted on 24/5/13 at 07:46 PM Reply With Quote
How do you know?
Sloan85
posted on 24/5/13 at 07:52 PM Reply With Quote
Thanks for that. Ill get these fixed tomorrow hopefully. How did you fix to the arch to the car?
40inches
posted on 24/5/13 at 08:11 PM Reply With Quote
Stainless button head allen screws, with stainless penny washers both sides of the panel, if the nuts were in an area that was going to be skinned, ie: cockpit sides, I fitted stainless countersunk 6mm rivnuts into a large washer and bonded the washer to the inside of the panel with epoxy resin. you can get at least 2 screws each side into the chassis tubes.
stevegough
posted on 24/5/13 at 08:54 PM Reply With Quote
link to earlier thread: fitting wings
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
Barkalarr
Contributor
Posts 941
Registered 14/3/12
Location Essex
Member Is Offline
Photo Archive Go!
posted on 24/5/13 at 10:25 PM Reply With Quote
How do you know?
Fat bloke in the pub told me..... doh !! Linky
posted on 25/5/13 at 08:21 PM Reply With Quote
On the front half of the wheel arch, you can pick up the chassis rails and insert rivnuts. On the rear panel, just use nuts and bolts with large washers. We used nylon nuts and bolts to fasten the arches on our MK. Idea being, that if they get hit, the nylon bolts will snap before the arch/side panel/rear panel take much damage. At least that's the theory...
Phil
New Topic New Reply
