Author: Subject: Garage clear out.
big_wasa
posted on 26/5/13 at 11:40 AM Reply With Quote
Garage clear out.
Well a week has passed so I am clearing out all the bits I've found stashed in the depths of my garage. Some I had forgot that I had.
Mt75 gear box not the most loved of the ford rwd gearboxes but will take more grunt than a T9.
Zetec / Mtx75 2.0 flywheel. Ideal for above and a zetec.
New Sachs 3 piece Zetec / Mtx75 2.0 clutch (240mm)
(The only thing needed to mount the above to a zetec is a longer pivot pin from Gbs.)
All the above £150 (That's what a t9 would cost you these days with out clutch). Collection only.
St170 Inlet manifold complete. £60+£10 postage
Tiny Denso alternator, bought as new old stock ie been sat on a shelf for x amount of years but not fitted. Now has alloy 6 rib pulley and also sourced a plug. £75+£10 postage.
Ford dohc starter, The one you want for a zetec and is the longer skinnier one instead of the shorter fatter cvh. Again new old stock. £50
Full set of front ball joints. Better quality Qh maxi joints that are pressed from the bottom not the top, very hard to get now. Mk2 Escort track rod ends and transit drag links with half lock nuts. £50+£10 postage.
Bits and bobs. These bits are make me an offer + postage I don't have a price so if you want it make me an offer or watch out for them on ebay.
St170 / black top zetec sump, cut and shut to 165mm aprox. The bottom bit needs a bit more grinding down where the starter goes. and a dam good clean. Home made.
2.0 black top ecu + 2 rdif chips with wiring plug.
Sierra indicator stalk. sold sold sold HD
Sierra ignition barrel + 2 keys
Sierra ignition switch.
Sierra steering / indicator self cancel spacer. Sold sold sold Hd
Ford clutch gator with spring, should fit mt75 and T9 Sold sold sold CL
Little spring that spaces cowl from column ( found two ).
Sierra column rubber bush and retaining clip ( no plastic triangle bush)
Gear stick gator with chrome trim and screws ect.
Sierra 3 pin flasher relay and plug.
Mondeo mk1 2.0 throttle body.
I wonder if there is anything elts
Any questions give me a shout, I have a few Scooby and rover bits aswell so every thing left will go on ebay tomorrow.
[Edited on 26/5/13 by big_wasa]
ChrisLeary
posted on 26/5/13 at 02:05 PM Reply With Quote
Can I have the mt75 clutch lever gaiter please?
Chris
Don't force it! Get a bigger hammer...
big_wasa
posted on 26/5/13 at 04:20 PM Reply With Quote
Make me an offer I can not refuse then
tims31
posted on 26/5/13 at 10:49 PM Reply With Quote
Hey Warren
I'll take the flasher relay please, I'll pop round one evening and pick it up if thats ok?
Getting funds for the IVA????
[Edited on 26/5/13 by tims31]
Build: http://www.martinsfurybuild.co.uk/
big_wasa
posted on 27/5/13 at 05:42 PM Reply With Quote
Originally posted by tims31
Hey Warren
flasher is yours mate, erm not exactly. The forms have already gone in, just not by me
tims31
posted on 28/5/13 at 08:29 AM Reply With Quote
Oh, that doesn't sound good , ok to pop round sometime this evening or tomorrow evening?
big_wasa
posted on 28/5/13 at 08:35 AM Reply With Quote
Yep
allart
posted on 29/5/13 at 12:27 AM Reply With Quote
Hello, do you know the torque rating of the clutch? I am planning on pushing 280lbft for the engine build this would be used for and wondered whether the clutch will be at all useable.
I am interested in the gearbox but will need to confirm.
Thanks, David
big_wasa
posted on 29/5/13 at 09:04 AM Reply With Quote
It's a standard oem spec replacement, I dont know how I would find out the specs ? Any ideas ?
