Poorscousertommy
posted on 29/5/13 at 05:02 PM |
Couple of random questions
'Ello folks, help needed again..
1. Does anyone know what lower ball joints are used on the indy R? Got in the garage for first time sine finishing uni and the rubbers have perished!
They were only trial fitted from new!!!
2. Where can I source a handbrake cable (sierra - calipers), and does anyone have an idiots guide to fitting? If speedy cables is the answer,
I'm going to need some help with routing so I can figure out length.. As always, appreciate the help
posted on 29/5/13 at 06:43 PM |
Try your local motor factors for replacement ball joint rubbers, since they became an MOT item most seem to stock them . Remove one of the old ones
and take it as a pattern. Can't help with the handbrake cable .
snapper
posted on 29/5/13 at 07:13 PM |
I shortened mine
Drilled a bolt lengthways
cut to match original ferul length
Threaded cable through with adjusters on cable fully in adjusted
Marked position, took cable off
Re threaded modified bolt, smacked it twice with a blunt chisel
Cut extra cable leaving an inch proud, mig it to a ball
It's been on 5 years
I eat to survive
I drink to forget
Madinventions
posted on 29/5/13 at 10:30 PM |
These cables will fit Sierra calipers:
http://www.trailertek.com/acatalog/Non-detachable.html
Here's a photo of them fitted to mine:
http://www.madinventions.co.uk/mojo/Images/handbrake4.JPG
View my band website:
http://www.shadowlight.org.uk
Sloan85
posted on 30/5/13 at 06:06 AM |
I used Ford Sierra (GBG GB4 GBC) Inc Hatchback &' Estate - Pagid Rear Handbrake Cable | eBay.
Fitting it is in by build diary here and
here.
http://mkindygsxr.blogspot.co.uk
Poorscousertommy
posted on 30/5/13 at 02:00 PM |
Legends - the lot of you!
It never ceases to amaze me just how good this forum is - thanks folks.
steve8274
posted on 30/5/13 at 02:41 PM |
For your balljoint rubbers try ebay link below. They do different sizes
http://bit.ly/ZvOLSH
