New Topic New Reply
Author: Subject: Throttle cables
Matt21
posted on 29/5/13 at 07:57 PM Reply With Quote
Throttle cables
Hi all
im matt and ive just signed up on here
I bought myself an MK Indy last week after borrowing my girlfriends dads fisher fury to enter a race in, i just had to have one myself!!
a couple of days after getting it the throttle cable ended up snapping and im not sure where to get a new one from!
it is 1.7meters long
has a 6mm eye on one end (to go over a bolt on the bottom of the peddle)
and has a lead barrel nipple on the other end to go the the throttle on a 919 fireblade engine
can anyone help me out? even a universal 'make it yourself' kit would be enough!
its just bodged together atm so i could get it home!
thanks!
Poorscousertommy
posted on 29/5/13 at 08:07 PM Reply With Quote
Not used them myself (yet), but most on the forum recommend speedycables (www.speedycables.com).
HTH
Matt21
posted on 29/5/13 at 08:14 PM Reply With Quote
thanks, set a request off to them to get a price
anywhere else to try?
or does anyone know if the cable i have is off another vehicle? bit of a long shot i guess!
wombat
posted on 29/5/13 at 08:59 PM Reply With Quote
Try your local motorcycle shop, mine has made cables for me for mx bikes, karts, law mowers and all sorts. Take old one with you for a pattern.
Hopley89
posted on 29/5/13 at 09:17 PM Reply With Quote
Hi an welcome to the site ..
Iv got an escort throttle cable if that would be any use to you
If you send me a u2u with email ill send u a couple of pics
Dan
mark chandler
posted on 29/5/13 at 09:21 PM Reply With Quote
Mine uses a push bike rear brake cable, no point making it expensive, in the old days for long runs you cut down a hillman imp cable.
[Edited on 29/5/13 by mark chandler]
rdodger
posted on 29/5/13 at 09:24 PM Reply With Quote
Venhill have some good stuff.
Sloan85
posted on 29/5/13 at 09:28 PM Reply With Quote
Something like New Venhill Universal Throttle Cable Motorcycle Trials Kit, great product | eBay maybe.
http://mkindygsxr.blogspot.co.uk
posted on 29/5/13 at 09:36 PM Reply With Quote
Throttle cables break because the pedal is pulling the cable taught at full throttle, the pedal movement should only pull the throttle to 99% open not 101% or even 100%.
Matt21
posted on 30/5/13 at 01:00 AM Reply With Quote
Thanks for the replies.
I've tried a brake cable, the barrel nipple is too big though. It could be filed down to fit if needs be I guess....
As for the reason why it snapped. Indeed you are right, the first thing I did was make an adjustable pedal stop. It was only a couple of days after buying it
mark chandler
posted on 30/5/13 at 07:42 AM Reply With Quote
Filed mine down now you mention it
New Topic New Reply
