Author: Subject: small roller bearing
chicade
posted on 31/5/13 at 02:26 PM Reply With Quote
Hi I am searching for 36x 3mmx3.5mm loose roller bearings searched net to no avail help required from the collective they are for a connecting rod on a cutting machine many thanks chicade
MakeEverything
posted on 31/5/13 at 02:58 PM Reply With Quote
Try Brammer.
Kindest Regards,
Richard.
jamiepearson69
posted on 31/5/13 at 03:18 PM Reply With Quote
Or try
http://www.eabs.co.uk/
Very helpful and if they exist, they should be able to get you one!
Unfortunately some manufacturers (Yamaha) make their own silly sized roller bearings which are impossible to get hold of without going directly to them!
rick1962uk
posted on 31/5/13 at 06:05 PM Reply With Quote
thats an odd size have you got the right sizes you need the id/od and with so would it be 36 x 33
i use vxb.com they list just about every bearing made and bearink-kink.co.uk these also do seals at great prices
[Edited on 31/5/13 by rick1962uk]
DarrenW
posted on 3/6/13 at 04:39 PM Reply With Quote
If 36 is the ID, OD should be 42mm assuming the thickness is 3m radially. Not really a small bearing, but 3.5mm thick sounds unusual. maybe a quick sketch and some ball park dimensions would help.
phelpsa
posted on 3/6/13 at 04:59 PM Reply With Quote
I think he wants 36 off 3mm dia x 3.5mm long cylindrical rollers.
DarrenW
posted on 3/6/13 at 08:53 PM Reply With Quote
Oh yeah, that makes sense. So just the needle rollers then. Its not often that people only want them unless they are a bearing manufacturer / reseller.
