<<  1    2    3    4  >>
Author: Subject: Locost Project Thread
daveb666
posted on 7/6/13 at 09:59 AM Reply With Quote
As I've owned my Locost for a few weeks now I thought it was probably about time I put a project/diary thread up as a record of what I get up to.
Firstly, this won't be a 'build' thread. The car was 99.9% complete when purchased from "big_wasa" and pretty much just needed to be put through an IVA to get road-ready.
Apologies for picture quality, most are taken on my mobile
Spec from the advert:
2.0 Zetec rebuilt pre aug 95 with letter from ford.
fuel injected
Scholar sump
Scholar lightened flywheel
Dunnel alternator kit
Mt75 gearbox
Fisher stainless exhaust manifold
Capri atlas axle
Cortina fronts
Gaz shocks
D&F prop
Cai dials
Obp pedal box
Obp fuel tank
Obp catch tank
Mk2 escort steering rack Quick ratio 2.9:1
Front wish bones 4" wider than stock to match the atlas rear axle
Sierra column
Momo 10" caterham steering wheel
Gts fiberglass
Descent 15" alloys pug offset
Advert pictures:
So after agreeing a deal with Warren, I left got the car transported back home. Warren told me a bout a few little IVA jobs that would need doing, so whilst the IVA application paperwork was winging its way to VOSA, I took the usual 'pre-IVA' pics for people to look for things that may need sorting.
Pre-IVA Photos
First thing that I noticed was that trim needed adding to the bottom of the headlight brackets (yes they will get painted!)
Lambda sensor needed wrapping
Breather pipe from the rocker cover to the catch tank needed purchasing and fitting
It was suggested that it would be prudent to put some sort of threshold cover on for the IVA, and to prevent scratches in future. I purchased some Cope Moulding #11 from Click Metal and cut it to length. I wasn't keen on the bare metal though so wrapped it in 3M carbon fibre sheet.
Before:
After:
I then phoned VOSA to chase my application, as it was over a week since I had paid. I was told that they are 3 weeks behind so my test date will be at least 6 weeks away! :-\ So I decided to start tinkering as I had time to spare.
First job I wanted to do was to paint the mesh in the nose-cone as it was bare metal and starting to look a bit shabby.
Nose cone Removed:
Nose cone off the car:
All masked up on the painting bench
Primed (poor photo, apologies)
While painting the cone, I decided it would be a good idea to carbon wrap the indicator brackets, so removed them from the nose-cone and dismantled:
That's where I got to last night, will update the next bits.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   daveb666 's Aim
Ben_Copeland
posted on 7/6/13 at 11:33 AM Reply With Quote
Looking good, be careful or you'll end up with the engine in bits upgrading stuff ;-)
Ben
Locost Map on Google Maps
Enter Your Details Here
View User's Profile View All Posts By User U2U Member   Ben_Copeland 's Aim This User Has MSN Messenger
posted on 7/6/13 at 11:45 AM Reply With Quote
Too much stuff in the skip! Apart from that looking good.
big_wasa
posted on 7/6/13 at 01:51 PM Reply With Quote
You not painted them light brackets yet Talking of lights did you find out why the O/s side one was on the slosh ?
daveb666
posted on 7/6/13 at 01:59 PM Reply With Quote
Nope - the mounting screw was still in tight in the hole! Tried to open the springs that holds the glass in place but couldn't get it to budge and was worried I'd end up smashing the glass, so I drilled a new hole in the lense cover and rotated it round into the correct place
@coozer; the skip is for the guy doing work on my house so not my concern lol
daveb666
posted on 25/6/13 at 10:00 AM Reply With Quote
Minor updates;
Painted the headlight mounts;
Completed the painting of the front mesh and swapped the front indicator lenses for clear ones
Naked car!
Whilst the bodywork was off the car I got out the rubbing compound my rotary polisher and gave everything a pre-IVA buff
The dog wasn't impressed
Whilst at Newark I saw some of these indicators on a stunning MK so decided to get a pair, ready to fit after my IVA
Car was then wheeled back into the garage ready for IVA day; 4th July!
daveb666
posted on 4/7/13 at 04:43 PM Reply With Quote
Updated with IVA post
So, IVA day.
Got there nice and early and unloaded
Got in, did the emissions test- failed. (Weird, water temp on 90 and car was very warm)
Gary (tester) said to let the car warm up some more. (Car fan come and on and off a couple of times it was that warm!)
Waited...waited...waited
Retested.... failed.
Asked Gary why it said "CAT" on his testing machine, and after a quick discussion it was agreed the car should be tested without a CAT on it (1993 engine), oops.
Gary played around with the machine and 2 minutes later I got a pass straight away. Phew, on to the next bit!
Moved up on to the ramp up and turned the car off. Up and down we go and Gary looked under the car, around the front wheels etc. Light test all done with some minor adjustments on the headlamps as expected.
Gary asked me to move the car forward and...it wouldn't start! Wondered if it was the battery, but turned over nice and fast! Waited 5 minutes, same thing. BOLLOX!
Gary said he'd complete as much of the test as he could so I'd hopefully fall under the 3hr (300!) re-test category.
I went back to the waiting room to sulk. 55 minutes later Gary waves me into the testing area,
"I've managed to get the car started so we'll carry on!!!"
Back to the waiting room I go, and another 90 minutes (2.5hrs in total) later Gary brings back the sheet of paper to the office, with the FAIL information:
So -
Brake bias bar locking mechanism. I plan on adding a split pin (See other forum for info)
Seats - don't really understand that one, but I was going to replace them with GRP ones anyway so that's just speeded up that process!
Mirrors - this was mentioned in the original post but I thought they'd be OK. Apparently they're not, so new ones will be ordered.
Headlights - Gary forgot he let me adjust these so that technically shouldn't be there.
Not AS bad as it could have been. Need to sort out the hot-start issue too!
daveb666
posted on 4/7/13 at 04:47 PM Reply With Quote
Offending seats removed:
Offending mirror:
Brake Bias Bar:
Now to buy some new stuff
[Edited on 4/7/13 by daveb666]
big_wasa
posted on 4/7/13 at 05:55 PM Reply With Quote
I am very annoyed with the seats failing as they where bought just for the iva after the introduction of the rear head rest.
They where bought from Midland wheels And the baby cub has been fitted to hundreds of cars and gone through iva ?
Mirrors, guessed they where marginal on the edges.
Bias bar, Its funny how different vosa centres enforce the rules. Its a good job your nice and slim to get in there with the drill.
All in all a very good fail and I am very pleased for you
I would see if the hot start thing does it again. But I have got a few ideas.
daveb666
posted on 16/7/13 at 07:58 AM Reply With Quote
So, new Mirrors ordered from Furore Products (top service Russ - highly recommended!)
Didn't want to make anyMORE obvious holes in the bodywork so fitted them through the edge of the aeroscreen; that way if I change at a later date the edge trim will cover the hole I've made.
(edge trim still needed adjusting in this picture!)
Not sure I really like the look of the mirrors to be honest, but if it passes the IVA then that doesn't matter for the moment.
Needed some new seats so went for GRPs. After a previous post about the quality of some KAD seats I'd decided to buy them, but they didn't have them in stock so I had to go for some more expensive ones from http://www.kitspares.co.uk/
The finish is probably the same as the KAD ones (same supplier probably) but they feel very solid. The guys at Kit Spares were great as well and the seats arrived as told, 20 hours after ordering.
So, on to fitting my new seats. Eventually the drivers will be mounted on runners so the wife can have a drive, but for the moment I just banged it on some bobbin mounts to get it level, and absorb some vibration
Drivers one now all finished; drilled the holes wrong in my passenger one so need to do that tonight. DOH.
posted on 16/7/13 at 08:09 AM Reply With Quote
Looking well
It will be good to see that car on the road!
daveb666
posted on 22/7/13 at 05:45 PM Reply With Quote
sooo today I passed my IVA!!!...and now move on to the saga of the DVLA
Whilst waiting for my DVLA inspection next week I got on with fitting my carbon rear arch covers:
Mocked up with PAD (paper-aided-design)
Drill some holes and then fit
..and then realise you've not got enough black rivets
Dominator headlights going on next.
daveb666
posted on 22/7/13 at 06:03 PM Reply With Quote
Had some more time this afternoon to look at the hot-start issue. I was speaking to a Ford Mechanic about what he thought the problem was, and he seemed to think that it was fuel vaporisation due to the fuel pump being located in the engine bay.
So this afternoon I let the car idle and warmed up to around 95 (just before fan kicks) and kept my hands on the floor pumps. They were cool, certainly not warm.
I let the car carry on running and then the fan kicked in; due to where the fan is, and where the engine sites all the hot air that the fan sucks through from the rad heads straight down the inlet side of the engine - right on to the fuel pump. It felt like a hair dryer on the pump/filter.
By the time the fan had gone off the pump/filter were red hot; I guess that's the problem then!
Pump/Filter before:
Pump/Filter after some heat resistant wrap was added on to it:
Ran the car up again and let the fan come on and off and the pump was nice and cool still, hopefully that'll have sorted it.
big_wasa
posted on 22/7/13 at 06:09 PM Reply With Quote
gets some vents cut in the bonnet to let the air out.
daveb666
posted on 26/7/13 at 07:12 AM Reply With Quote
I wanted to replace my 'friendly' front indicators every since I saw some motorbike ones on a stunning white MK at Newark. I'd already bought them and was just waiting to get through the IVA procedure before fitting.
Old ones
New Ones
Yes I know they're little but loads of cars have these and they are, surprisingly bright.
Whilst fitting these, I'd noticed that the induction kit was right behind the radiator, which can't help with cool air so, after spying a discount Carbon NACA duct I set to work fitting it.
(All likelihood is this will be redundant once the TBs go on but I like the look of it, and any cool air in to the engine bay can't be a bad thing)
big_wasa
posted on 26/7/13 at 11:23 AM Reply With Quote
You want some vents at the back of the bonnet to let the hot air out.
Have you took them head light spacers out yet ?
daveb666
posted on 26/7/13 at 11:32 AM Reply With Quote
Yeh i know; can't decide on the design yet though and was itching to get this vent in
Headlight spacers? The headlights are coming off next week to be replaced with black Dominator ones to hopefully 'harden' up the front of the car a bit.
loggyboy
posted on 26/7/13 at 11:38 AM Reply With Quote
Assuming the pump generates its own heat wont this be insulating it? Surely the wrap should be on a small sheet of metal thats between the pump and the other heat sources?
Mistral Motorsport
big_wasa
posted on 26/7/13 at 11:40 AM Reply With Quote
Yeh the headlights are jacked up on spacers to meet the min height for iva.
daveb666
posted on 26/7/13 at 11:44 AM Reply With Quote
oic. The dominators are going to be mounted straight to the 25mm tube (hence my question earlier in the week) so the spacer mount at the end will be chopped off
daveb666
posted on 31/7/13 at 07:42 AM Reply With Quote
So on Monday I passed my DVLA inspection - now just a waiting game for the paperwork.
I bought some Dominator headlights a few weeks ago as I wanted to replace the chrome ones to give the car a slightly harder look.
The original headlights come with an open gromett, which I don't really like
So I replaced that with a full 38mm gromett from Ebay and punctured a hole in it.
No 'fitting' pictures, so on to the first completed install;
I queried how to route the cable yesterday, and decided to go through the end of the 25mm pipe with a wrapped cable (this will be replaced once my black silicone hose arrives)
Both headlights on
Bodywork all done
Finished article
Really happy with how the car looks now - just want to drive the bloody thing!!
daveb666
posted on 31/7/13 at 01:42 PM Reply With Quote
Sorry loggy, only just seen this. Fuel pumps are self-cooling due to the fuel going through them. These were only getting warm because of the heat from the fan.
daveb666
posted on 20/8/13 at 07:00 AM Reply With Quote
Spoke to Carbon Copies and got a couple of rear vents for the bonnet:
...and then THIS happened!!
daveb666
posted on 2/9/13 at 07:43 AM Reply With Quote
So I've put some miles on the car and had a few shakedowns:
Then I broke it - the starter motor seized, it wouldn't start and I couldn't jump it. I had to call my Dad to tow me to his house. I then removed the starter motor, and drove home.
The starter motor was a Lucas (LRS707). For those of you that may need one of these in future, a company called Wood Autos in Huddersfield stocks a smaller, lighter replacement:
The part number for your reference is STR50041 and it costs about 60.
Unfortunately, me driving home without the wires to the starter connected overloaded the alternator, so today I need to get a new regulator for that.
daveb666
posted on 2/9/13 at 07:49 AM Reply With Quote
Because I needed to remove the alternator anyway, and to do this easily meant taking off the inlet, I decided to start fitting my GSXR throttle bodies.
GSXR 1000 Bodies (75 ebay)
ST170 Complete Inlet and Fuel Rail (40 ebay)
MBE Loom and ECU (250 ebay)
(testing on the laptop)
In this picture the throttle bodies have been spaced to match the ST170 inlet, at this point I'm filling the 2nd butterfly holes in the bodies and filing back.
<missed loads of pictures here>
The complete bodies
The engine setup as it stands, pre-TB fitting:
The induction kit was suffering from massive heatsoak, so I heatwrapped an old airbox and did a direct feed straight into the box from the carbon scoop on the bonnet, hugely improved the performance of the car.
Inlet and alternator removed
TBs offered up for encouragement
I then pulled all the engine loom through into the car, dropped the dash, smiled at the general tidyness and skill of big_wasa's wiring abilities, and then gave up for the day.
<<  1    2    3    4  >>
