Author: Subject: Mig Gas solenoid 220v 50Hz Required? where from?
Benzo
posted on 11/6/13 at 11:30 AM Reply With Quote
Hi guys,
My Mig has been playing up, its not closing off the gas properly, i need a Solenoid like the one ive pictured below -
its a 220v Solenoid, 50Hz, 10Bar. - Manufactured by CEME.
Found a 230v one online, but i assume it wont work?
https://www.weldequip.com/gas-solenoid-valve.htm
Any help would be great!
[Edited on 11/6/13 by Benzo]
cliftyhanger
posted on 11/6/13 at 11:41 AM Reply With Quote
Why not? same spec, just different adapters. Probably find they will swap (no guarantee, but would be a reasonable assumption)
Gas solenoids are nothing special. Honest.
Benzo
posted on 11/6/13 at 11:48 AM Reply With Quote
not worried about the fitting, just not too up on the electrical side of things, can i use a 230v solenoid where 220v used before is the question really?
Slimy38
posted on 11/6/13 at 11:59 AM Reply With Quote
You should be fine. There tends to be that much variation in mains supply anyway, and there won't be anything clever in your mig machine to ensure exactly 220v.
Benzo
posted on 11/6/13 at 12:07 PM Reply With Quote
Ok thank you, part now ordered!
posted on 11/6/13 at 12:12 PM Reply With Quote
Weldequip has them in a range of voltages, they are used in euro torch conversions. 220v is nominal, they handle anything up to around 240v. Have you tried a spot of oil in yours to see if it the valve sticking ?
Litemoth
posted on 11/6/13 at 01:25 PM Reply With Quote
The voltage tolerance is quite wide on the solenoids.
I used this.
GAS SOLENOID TO SUIT MIG AND TIG WELDERS, AND PLASMA`S CUTTERS | eBay
Make sure you install in the right direction or they'll leak. (ask me how I know)
Benzo
posted on 16/6/13 at 11:17 AM Reply With Quote
Originally posted by Benzo
Hi guys,
Just to finalise this thread, ordered at lunch time from these guys and the component was with me from mainland uk to N.Ireland at 9am the next morning.
Pleasant guy to deal with on the phone, i would t hesitate to use these guys again!
Iain
KELLSY84
posted on 21/6/13 at 01:57 PM Reply With Quote
weldpro
give weld pro a ring and speak to Davy, i'm sure he could help you out with anything else. Sydenham Rd Belfast, County Antrim BT3 9DJ
028 9045 6232
[Edited on 21/6/13 by KELLSY84]
Benzo
posted on 21/6/13 at 02:06 PM Reply With Quote
028 9045 6232
Got a torch from weldpro about 4weeks ago.. Seems like a good outfit, pity I'm based in Derry!
