Author: Subject: Where can i get some GRP half doors for an MK Indy?
smitht82
posted on 12/6/13 at 04:22 PM Reply With Quote
Does any one know where I can get some GRP doors to fit the MK Indy? I know softbits do the material ones but I really want some Black GRP one with an elbow buldge.
Either that or can someone show me a pic of their homemade ones?
Thanks in advance!
stevegough
posted on 12/6/13 at 04:37 PM Reply With Quote
not if your car's as small as your avatar picture!!!
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
smitht82
posted on 12/6/13 at 05:10 PM Reply With Quote
LOL that was timing as I was just trying to redo my pic size :-)
Not Anumber
posted on 12/6/13 at 05:25 PM Reply With Quote
I'm using GBS Zero weather gear and doors on my Indy. Though the Indy cockpit length is longerthan the Zero the weather gear fits fine when the windscreen is mounted a bit further back on the scuttle (nearer the dash). The scuttle step, the usual windscreen base position, then becomes the perfect place to mount the windscreen wipers.
kajzw
posted on 12/6/13 at 05:33 PM Reply With Quote
Have a chat with Julian at Aerodynamix - I'm sure he could help you out.
stevegough
posted on 12/6/13 at 06:11 PM Reply With Quote
Funny you should say that, I have the Zero doors and roof, too on my Luego....but the doors are the type smitht82 said he didn't really want - unless you have a different type to mine?
Luego Locost C20XE.
peter bland
posted on 12/6/13 at 07:22 PM Reply With Quote
Some pics in my photo archive, home made , work great.
Johneturbo
posted on 13/6/13 at 09:08 AM Reply With Quote
they look very good, how did you make the mould do you still have it, trying to make some for the mnr!
40inches
posted on 13/6/13 at 09:18 AM Reply With Quote
From a comment in his archive, bit of lateral thinking
"Hi,I used 1mm sheet metal ,which bends quite well and for the hump I bent the sheet over a 6in silencer and tack welded it"
Johneturbo
posted on 13/6/13 at 04:49 PM Reply With Quote
Actually I think it might have been me that asked the question!
peter bland
posted on 13/6/13 at 05:21 PM Reply With Quote
Yes still have the moulds, my mate has a MNR and is going to try my doors to see how good a fit they are.
40inches
posted on 13/6/13 at 07:01 PM Reply With Quote
So it was
