New Topic New Reply
Author: Subject: Wiwood Rear Calipers
RJK350
posted on 16/6/13 at 07:48 PM Reply With Quote
Is anybody using wilwood rear callipers on their MK Indy?
If so do they fit inside 13" wheels.
Also which callipers are they and do they fit straight to the MK up right?
eddbaz
posted on 16/6/13 at 11:50 PM Reply With Quote
Got them fitted on my Indy, not much clearance on my 15" wheels, certainly won,t fit 13" wheels.
ashg
posted on 17/6/13 at 01:15 AM Reply With Quote
nope you will need 15's there is about 5-10mm between the handbrake mechanism and the rim on my car with 15inch team dynamics wheels
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
snakebelly
posted on 17/6/13 at 08:48 AM Reply With Quote
We have them on our Tiger GTA running 14's have modded the rear suspension so in theory they will fit under a 13 but havent checked fully yet and even if they do it will be very very tight.
SausageArm
posted on 17/6/13 at 08:57 AM Reply With Quote
Are the MK Indy the same as the Mac#1 at the rear end? sierra rear bearing carriers and hubs? if so speak to Mac#1, they can supply you brackets and discs to fit the Wilwood handbrake calipers and fit behind 13" wheels.
Here's the rear brakes on my Mac#1 Worx
Rear upright
Sierra bearing carrier fitted to uprightband bracket painted/fitted to bearing carrier
Bracket and hub fitted
Disc and caliper fitted
Not the best photo but they fit behind 13" Team Dynamics Pro 1.2 wheels
bigrich also had them on his Mac Worx,
[Edited on 17/6/13 by SausageArm]
Custardpants
posted on 17/6/13 at 03:55 PM Reply With Quote
Sausage I couldn't help but notice that you only have one rose joint on your lower arm - can you elaborate? Looks good, and cheaper than rose jointing the whole lot!
Dunbikin
posted on 17/6/13 at 05:50 PM Reply With Quote
Is it me, or is that shock on upside down.
Ron said it would cost 250 quid. My wife thinks it did.
rdodger
posted on 17/6/13 at 07:02 PM Reply With Quote
One rose joint to adjust rear toe.
I have a cammed bolt to do the same thing. Like an MX5.
Shocks are valved to be that way up I believe.
I also have 13" prorace with willwood calipers. Not the disc ones though you need the drum conversion from RD.
RJK350
posted on 17/6/13 at 07:30 PM Reply With Quote
Thanks for all the help guys.
Especially all the photos. Thanks SauageArm
coyoteboy
posted on 17/6/13 at 07:49 PM Reply With Quote
Assuming it's designed to be that way up, it's far better to have it that way up (reduced unsprung mass).
Dunbikin
posted on 18/6/13 at 01:45 PM Reply With Quote
That makes perfect sense. That's why I like this site so much, I learn something new nearly every time I come on here.
Twin40
posted on 20/6/13 at 08:04 AM Reply With Quote
Yep i'm running wilwoods on the rear and 13" compmotive CXN's, doesn't fit straight on, had to machine the spacer plates to allow clearance!
SausageArm
posted on 20/6/13 at 08:14 AM Reply With Quote
Yeah, that's correct.
No problem. :-)
SausageArm
posted on 20/6/13 at 08:19 AM Reply With Quote
I forgot to mention earlier that to fit the discs Mac#1 supply, the rear hubs need a small amount machined off the outside diameter to fit inside the brake disc.
New Topic New Reply
