Author: Subject: o-rings suddenly now oversized or bigger??
aka Keith
posted on 28/6/13 at 10:35 AM Reply With Quote
Having just dismantled my cars, to get the to bottom of some flodding issues, I have gobe to put them all back together. was going to put the rubbers back on when I noticed that the o-rings around the trumpets seem to have got larger, ie they now do not sit in their respective grove.
what is going on, never seen anytihng like this before.
any help?
Craig
Daddylonglegs
posted on 28/6/13 at 10:41 AM Reply With Quote
I've had that issue before on different parts. I think they swell with age (a bit like my belly!) I recently had that issue with a manifold on a boat engine and just cut a small amount of the O-ring out and super-glued the ends. It worked fine.
posted on 28/6/13 at 10:56 AM Reply With Quote
Yes they swell quite often a buggeration problem I encounter on the fuel pump housing of cars with in-tank pumps anf filter.
The cheat is wash the O ring in warm soapy water (use hand soap not detergent) and allow it to air dry in a warm place this works in most case.
aka Keith
posted on 28/6/13 at 11:28 AM Reply With Quote
Many thanks All,
Craig
richmars
posted on 28/6/13 at 01:37 PM Reply With Quote
The swelling means the material is wrong. They shouldn't, and will not work as well if swollen (the o ring could be damaged when it's pushed into the groove).
posted on 28/6/13 at 04:41 PM Reply With Quote
Even Viton O rings used to seal the pressure regulators in fuel injection rails swell to the extent they are difficult to re-fit but a gentle water wash and a few hours to dry works wonders.
maccavvy
posted on 29/6/13 at 06:47 AM Reply With Quote
could always replace them for the few pence they cost...
I just replaced mine on my bike carbs as it was leaking fuel from the inlet pipes.
Understeer , when the front hits a wall
Oversteer, when the back hits a wall
Horsepower ,how fast you hit the wall
Torque ,how far you take the wall with you
