Author: Subject: interior panels
Fieldy
posted on 10/7/13 at 03:04 PM Reply With Quote
interior panels
Hi All
This is probably going to make me sound a little thick!
I’m looking to redo the interior of my Locost, it’s been stored outside for sometime and the interior has perished. I wanted to know where to get the materials from. The side panels and the back panel are what I can only describe as cardboard type stuff, the edges have got wet and have frayed. Does anyone know where I can get more of this type of stuff from? Or what other options do I have?
Equally does anyone know anyone in the Birmingham area that would be able to do the interior for me, potentially something smarter then the current cardboard solution!
Thanks in advance!
Matt
[Edited on 10/7/13 by Fieldy]
40inches
posted on 10/7/13 at 03:35 PM Reply With Quote
Sounds like MDF, you can get 3mm thick at Wickes, B&Q etc. or use 1.2mm thick ally sheet instead.
deezee
posted on 10/7/13 at 03:37 PM Reply With Quote
Sounds a lot like hardboard. Wickes are as good as any where else on the high street.
Fieldy
posted on 10/7/13 at 03:41 PM Reply With Quote
Ah, Hardboard, thats probably what it is, its not MDF as its layered but thanks for the suggestion.
I would do the metal option but if im honest my skills just aren't up to that!
Actually hardboard isnt layered either is it, humm, ill take a picture at the weekend and post it up
Maybe its plywood?
big-vee-twin
posted on 10/7/13 at 03:47 PM Reply With Quote
Probably Mill Board see here linky
http://www.triangleltd.com
Fieldy
posted on 10/7/13 at 03:51 PM Reply With Quote
I think we have a winner!! i cant remmeber what the finish is (not looked at the car for about 8 months) but i think that is the finish, ie not smooth.
Thanks very much, my question doesnt seem so stupid now ha!
Davg
posted on 10/7/13 at 04:37 PM Reply With Quote
Matt u would be better off replacing with ally or plastic as alternative.. Local sign writers or plastic suppliers may help and you can cut from cardboard template. Cheers D
Fieldy
posted on 10/7/13 at 04:51 PM Reply With Quote
Yeah i did think about using the ones that are on there currently as a template, will make life a whole lot easier.
Ok so if i use ally how do i secure it to the car? I presume i need to use rivits? How easy is that to do?
Davg
posted on 10/7/13 at 04:57 PM Reply With Quote
You can use pop rivets or stick it with pu adhesive. If you can drive an R1 bec surely you can work out how to work a pop riveter or mastic gun
Fieldy
posted on 10/7/13 at 05:05 PM Reply With Quote
haha its not that i couldnt learn to do it, machanically im good, but more craft based things i think i may struggle. I dont have the best patience in the world and tend to rush things... im the kind of guy that can fix most problems with a good old bit of gaffa tape!
I think im just going to have to bit the bullet and do it, i suppose i dont need to do any bends or anything so shouldnt struggle to much.
Davg
posted on 10/7/13 at 05:10 PM Reply With Quote
You betcha good luck and remember measure twice cut once
If you go ally use some pu adhesive as well, such as sikaflex or tigerseal etc.
If in doubt shout back up
Cheers D
iank
posted on 10/7/13 at 05:15 PM Reply With Quote
Or use 3M VHB tape they use the stuff to hold panels on trains and coaches - sticky as hell and as easy to use as any double sided tape (though you MUST get it in the right place first time )
ETA: The lightest solution is to not use anything and just admire your chassis as you drive along.
[Edited on 10/7/13 by iank]
Anonymous
