Author: Subject: Fast Diesel!
posted on 23/7/13 at 08:26 PM Reply With Quote
Fast Diesel!
May have posted this before but I just cannot get over the speed of this thing!
Daddylonglegs
posted on 23/7/13 at 08:51 PM Reply With Quote
tomgregory2000
posted on 23/7/13 at 08:52 PM Reply With Quote
That's acceleration and a half
dave_424
posted on 23/7/13 at 09:08 PM Reply With Quote
I like this, not bad for a 20 year old car with a manual gearbox. Very likely still running on the stock gearbox and diff.
https://www.youtube.com/watch?feature=player_detailpage&v=R6PJA9tb66E
[Edited on 23/7/13 by dave_424]
rdodger
He seems to have removed the particle filter!
jossey
posted on 24/7/13 at 07:01 AM Reply With Quote
I'm surprised more people don't use diesels in locosts etc. the 325d engine is rapid
I guess it's the sound which puts people off
David Johnson
steve m
posted on 24/7/13 at 07:22 AM Reply With Quote
And the weight, plus, i beleive all of the engines are very tall
jossey
posted on 24/7/13 at 08:34 AM Reply With Quote
Ohhhhhh I assumed the bimmer petrol n Diesel engines would be similar sizes
David Johnson
mcerd1
posted on 24/7/13 at 10:19 AM Reply With Quote
^^ diesel's are almost always bigger & heavier
(and BMW petrols arn't small to start with...)
the moden ones might be good in a tin-top, but do you really want a low reving turbo'd engine for a sports car ?
and even if you do - you've then got to deal with the modern ECU and varible geometry turbo (and all the other complex bis that seem to be the cause of 90% of breakdowns these days) or you junk that and go back to the old fashoned diesels with lots of turbo lag or only a small boost...
[Edited on 24/7/2013 by mcerd1]
jossey
posted on 24/7/13 at 10:27 AM Reply With Quote
Originally posted by mcerd1
Diesel's are almost always bigger & heavier (and BMW petrols arn't small to start with...)
Neither of those sound easy or fun.
That said a 330d BMW engine would be good if it could be fitted n wired up. The torque is immense
Well ill stick to running diesel tin tops n try get my tiger finished then.
David Johnson
blakep82
posted on 24/7/13 at 10:44 AM Reply With Quote
Benzine on here is doing it! And it works great
________________________
mcerd1
posted on 24/7/13 at 10:53 AM Reply With Quote
and fair play to him
I'd never say 'it can't be done' especially when you look at what some folk on this site have achieved already...
but personally I didn't even waant to deal with the bog std. EFI on my pinto, so I junked all of it and buoght some bike carb's
posted on 24/7/13 at 11:03 AM Reply With Quote
Don't forget the diesel Westfield as featured in PPC.
Heres the build thread..
http://forums.tdiclub.com/showthread.php?t=247471
blakep82
Same here. I stripped everything electronic off my vauxhall x20xev and went for simplicity. Its got 2 sensors on it now, and that it
mcerd1
posted on 24/7/13 at 11:13 AM Reply With Quote
another way to look at that is a light weight car with the right gears shouldn't need that much torque
take a light weight engined car producing the same power to weight but probably with alot less torque,
with the right gearing could give you very similar performance in a strait line, but when it comes to breaking and cornering the lighter car will have the advantage in most conditions...
but then changing gears all the time in traffic with the leight weight car could get a bit tiresome - at the end of the day its just the one that suits you best
posted on 24/7/13 at 11:48 AM Reply With Quote
And now I'm looking at Audi A4's and thinking of a mid inline engined 2 seater ... DOH!
Any examples of this? Theres a nice A8 4L V8 TDI engine on the bay.. I think that would like building your own Le Mans car!
Cant believe none of the manufacturers haven't come up with something???
How about this for donor?
http://www.ebay.co.uk/itm/2002-AUDI-A4-2-5-TDI-QUATTRO-SE-ESTATE-BLUE-180bhp-FSH-1-Previous-Owner-/121147938495?pt=Automobiles_UK&hash=item1c34fad 6bf
OR this
http://www.ebay.co.uk/itm/2005-AUDI-A4-SE-TDI-SILVER-DAMAGED-SALVAGE-B7-DIESEL-ESTATE-6-SPEED-MANUAL-81K-/300938417693?pt=Automobiles_UK&hash=item 461153d61d
[Edited on 24/7/13 by coozer]
blakep82
posted on 24/7/13 at 11:56 AM Reply With Quote
OR this
Not sure the quattro gearbox would be much good for a middy, but otherwise something I've very much been thinking myself for a little while now.
Nice audi v8 in a group c le mans type car... mmm
mcerd1
posted on 24/7/13 at 12:10 PM Reply With Quote
well the pertrol V8 + A4 box has been done in an esprit, so maybe you could build the diesel version
