Author: Subject: Wilwood assembly
Poorscousertommy
posted on 27/7/13 at 01:56 PM Reply With Quote
Wilwood assembly
Folks,
Bought my Wilwoods and associated Mintex 1144 pads from Rally Design some months ago, I got round to trial assembly today and they wont go together - can somebody sanity check that I'm not being completely stupid (a high possibility!).
When the pads are assembled into the caliper, the 'ears' on one of the pads clash with the mounting bracket like so:
I have also mock fit the assembly without pads, and all seems OK...
Have I been sold the wrong pads, cos they werent bloody cheap!!
Mark
bigfoot4616
posted on 27/7/13 at 02:18 PM Reply With Quote
pads are the wrong way round. the pad retaining clip goes on the opposite side of the caliper to the mounting bracket.
how you have it mocked up just slide the pads in with the mounting lugs at the back. the caliper will have a lug to retain the clip when fitted, plus holes for the clip.
on closer look at your second pic you can see the pad retaining clip behind the caliper, remove that fit pads and fit the clip through the holes in the pads and caliper.
[Edited on 27/7/13 by bigfoot4616]
Poorscousertommy
posted on 27/7/13 at 02:55 PM Reply With Quote
Sweet! Told you I could vey easily be doing something stupid
Thanks for the quick feedback.
Back to the batcave!
theprisioner
posted on 27/7/13 at 04:32 PM Reply With Quote
Looking at the gap each side from caliper to disc the distance looks unequal. This may cause problems if I am correctly viewing your pictures (thinks).
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
adithorp
posted on 27/7/13 at 06:41 PM Reply With Quote
The holes in the adapter bracket appear to be off-set slightly. Can you turn it the other way up to move the caliper more central in relation to the disc?... Or is it recessed for the bolt head?
The fact that you've managed to put the pads in the wrong way around and fitted the securing pin/clip without realising it should go through the holes in the pad... erm, don't take this the wrong way but... Kind of worrying!
http://jpsc.org.uk/forum/
jeffw
posted on 27/7/13 at 07:43 PM Reply With Quote
Might want to get someone to check before using them in anger.....
rdodger
posted on 27/7/13 at 07:52 PM Reply With Quote
I made a spacer between the drive flange and disc to bring mine inline. Only 2mm so no probs with wheel studs or spigot.
Poorscousertommy
posted on 27/7/13 at 11:14 PM Reply With Quote
They're fine apart from the pad issue (now fixed thanks to the collective wisdom) I didn't manage to fit the retaining clip the wrong way (as they simply won't go together - but appreciate the concern as its always good to have a second pair of eyes!). The pic was only a mock fit to figure how they went together - now fully assembled, disc central to pads and move freely - will post some pics tomorrow for a sanity check - thanks all for the help.
[Edited on 27/7/13 by Poorscousertommy]
bigfoot4616
posted on 28/7/13 at 12:21 PM Reply With Quote
as you say its now central so all ok. this thread has reminded me that mine aren't central. looked quite a lot when i first fitted them but measured disc to caliper and it was 1.5mm difference side to side so 0.75mm of center. due to the brackets for escort rs/capri uprights it wasn't going to be easy to fix so i left it. over 4.5 years, about 4k road miles and 30 odd trackdays later no problems.
