alland3851
posted on 28/7/13 at 01:43 PM |
Piston Size
Hi, I am in the process of rebuilding a 205 block from a transit. The pistons are Low compression. I want to change the pistons to HC . The marks on
the top of the piston is D .030. Is this an imperial size , If so what would be the correct pistons to fit in metric ?
Any help would be appreciated.
[Edited on 28/7/13 by alland3851]
Canada EH!
posted on 28/7/13 at 03:32 PM |
Don't know about metric, but it looks like the engine has been rebuilt once as that number would indicate a 30 thou imperial over bore.
omega0684
posted on 28/7/13 at 03:55 PM |
if its a 205 block you want to be boring it out to 93mm (maximum) and get a new set of pistons. a good machine shop will supply you with new pistons
and rings and if you ask nicely they will even put them on your rods for you. Unless you are planning to put some serious power through the bottle
end, in which case you want to go with forged pistons/rods etc, you could use the 2.9 v6 pistons (can't remember what engine they are from but
im sure someone will add in the detail) this will increase the engine capacity to 2094cc
the +.030 on the piston top is 30 thou bigger than standard, so its already had a rebore before.
This might help, but its in metric ,
OE Bore size 90.83mm
Bore sizes available 90.89mm / 91.25mm / 91.5mm / 91.75mm / 92mm / 92.5mm / 93mm
Engine CC 1998.35cc / 2014.22cc / 2025.27cc / 2036.35cc / 2047.46cc / 2069.78cc / 2092.21cc
[Edited on 28/7/13 by omega0684]
alland3851
posted on 28/7/13 at 04:00 PM |
Thought it had been rebuilt before. Don't really want to go for a rebore just replace the pistons with the HC ones. Anyone recommend who could
supply suitable pistons
omega0684
posted on 28/7/13 at 04:08 PM |
What do you plan to do? are you building a race engine, or just something with a bit of poke?
What is your budget? are you building on a budget etc?
there are loads of places that sell forged pinto rods and pistons (just google it) but for a quality set of both brand new, i would be surprised if
you saw much change out of a grand.
Burton Power sell them, PEC (performance engine components) sell then, farndon, are just a few.
alland3851
posted on 28/7/13 at 04:17 PM |
I am not buiding the engine for race etc. I acquired this 205 block as the engine in the car was knackered. I just want to run the car with a standard
set up. I am on a limited budget.
omega0684
posted on 28/7/13 at 04:27 PM |
so do you have a short block or a whole engine, if the engine definately needs a rebore and you are on a limitied budget, then contact a local engine
builder and ask for a quote for a 93mm bore and replacement std pistons to suit, this will give you a little extra, also check shell tolerances on the
crank and rods and replace if necessary, if they are out, you might need to have the crank reground and oversize shells put in instead (engine machine
shop can do this as well as your rebore) and you might as well get the block decked if you need all of the above needs doing
alland3851
posted on 28/7/13 at 04:34 PM |
Thanks for all the info. I will get in touch with my local engine shop.
omega0684
posted on 28/7/13 at 04:36 PM |
for a small fee they may even rebuild your bottom end for you.
posted on 28/7/13 at 04:38 PM |
A bit of common sense if it is rebored unless it was a genuine Ford exchange engine the pistons are likely to be high compression anyway, in my
experience UK engine shops very rarely fit low compression pistons.
jacko
posted on 28/7/13 at 05:49 PM |
Just what i was thinking
But if it has low compression piston's how about fitting a small turbo or supercharger
alland3851
posted on 28/7/13 at 06:19 PM |
H all, the reason I believed the pistons are low comp pistons was that the pistons have an L on the top and they don't come up flush wqith the
block. I had been told that this indicates that they are low comp.
snapper
posted on 29/7/13 at 04:58 AM |
If it was a Transit engine and rebuilt they would fit like for like
You can fit second hand pistons over size with new rings for cheapness
A good mod is to have block decked so pistons are flush this give more compression and better squish
I eat to survive
I drink to forget
alland3851
posted on 29/7/13 at 08:52 AM |
That may be a better option for me.
Thanks again for all the replies.
