New Topic New Reply
Author: Subject: Tunnel Width For SR20DET Engine and Box?
Chris_vrs
posted on 29/7/13 at 08:22 PM Reply With Quote
I have a Narrow Bodied Westfield Chassis and the previous owner has had a play with an angle grinder and welder.
They have created more leg room for the driver and passenger thus closing the transmission tunnel.
The width is now 200mm wide but I am unsure if this is wide enough to fit a SR20DET box
Can anyone help me?
www.gardencitylocksmiths.co.uk
tomgregory2000
posted on 29/7/13 at 09:02 PM Reply With Quote
I can't tell you as I no longer have my car, but on the sr20det gearbox there are two bosses that stick out either side of the gearbox right where the gear lever is as they hold the springs that return the gear lever to the middle, I had to cut a U section out of the up rights on both sides of the trans tunnel to get it in so get this measurement
tomgregory2000
posted on 29/7/13 at 09:04 PM Reply With Quote
Here is a pic for you
[Edited on 29/7/13 by tomgregory2000]
New Topic New Reply
