New Topic New Reply
Author: Subject: Fitting aeroscreen to scuttle?? Any photos??
Sloan85
posted on 7/8/13 at 09:01 PM Reply With Quote
i plan on riveting the aeroscreen to the scuttle but what is the best way to tidy the edge of the aeroscreen where it sits on the scuttle? I was thinking a bead of sikaflex or similar. Any other suggestions?
Any photos would be appreciated.
http://mkindygsxr.blogspot.co.uk
MsD
posted on 7/8/13 at 09:05 PM Reply With Quote
I'm yet to do mine but I've seen a few that use rubber u-trim around the edge- looks quite smart.
Mark.
puma931
posted on 7/8/13 at 09:08 PM Reply With Quote
Use a plastic u trim rather than rubber. The one I used had glue in the u so it grips the edge. Then use sikaflex to bond to the scuttle (I would not use rivets).
[Edited on 8/8/13 by puma931]
Sloan85
posted on 7/8/13 at 09:16 PM Reply With Quote
So U-trim all the edges? I was going to do that to the curved edges on the interior side where there will be sharp exposed edges. I'll see what it looks like on all the edges.
austin man
posted on 7/8/13 at 09:34 PM Reply With Quote
mine is just rivited I was going to mask it and silkaflex it befor painting but never bothered, I have also bonded on to a scuttle with fibreglass an smoothed it in with filler to make it look like a one piece
philhoward
posted on 8/8/13 at 06:24 AM Reply With Quote
I used a rubber U channel from Seals + Direct.
See Linky
puma931
posted on 8/8/13 at 06:59 AM Reply With Quote
Here is a picture of mine.
Use a heat gun when fitting the trim to get a good fit.
New Topic New Reply
