Author: Subject: Mnr Reverse box
mr T
posted on 8/8/13 at 08:36 PM Reply With Quote
Mnr Reverse box
Has anyone had any problems with there mnr reverse box just been for a blat went to put it in reverse and it worked fine pushed the lever down went to set of and northing put the lever up and down a few times and eventually it worked, also don’t no if this is related or its the clutch slipping but came home on the motorway put my foot down at speed in sixth and it felt like it spun the wheels up for a second the clutch feels the same and pulls away the same
mr T
posted on 8/8/13 at 09:04 PM Reply With Quote
Just had a thought if the clutch is dragging a bit and there’s tension in the drive train would this stop the reveres box from going back in gear its very stiff to lift the lever when the engine is in gear and the clutch is down when I put it in first to set of it clunks into gear as if it wants to move forward
renetom
posted on 9/8/13 at 06:40 AM Reply With Quote
sound like clutch to me
But could also be the MNR box
good luck
big_l
posted on 6/9/13 at 07:30 PM Reply With Quote
maybe try lovering the tick over my car jumps into first if i have the tick over any higher than 1300rpm
Check out my blog mnrvortxhayabusa@blogspot.com
View User's Profile E-Mail User View All Posts By User U2U Member This User Has MSN Messenger
