Author: Subject: Digit dash
dave107
posted on 17/8/13 at 12:43 PM Reply With Quote
Digit dash
I have a digi dash 2 lite and my question is how do I access the ODO screen As i cannot find it also i cannot find the battery voltage and fuel level screen, i need to send some photos with my insurance to Adrian Flux for the agreed value and one of the photos has to be the miles meter as proof of mileage.
Any help appreciated
Dave
Daverog
posted on 17/8/13 at 12:52 PM Reply With Quote
You should be able to scroll through the various screens using the left hand side ("A" button) and you will eventually get the ODO and all the other bits of data. Have you got the user information for it?? If not you can down load from the ETB site, it is under technical help, Digidash Downloads.
dave107
posted on 17/8/13 at 12:57 PM Reply With Quote
Thanks for quick reply yes I have all the information and I have accessed all this in the past when setting it all up, car passed IVA just over a week ago would they have wanted to see this all working then ? , does the engine need to be running or should it all work with ignition just turned on.
Daverog
posted on 17/8/13 at 01:15 PM Reply With Quote
It should work OK with the ignition turned on. I would check the multi plug connection on the back of the unit to see if that has worked loose.
dave107
posted on 17/8/13 at 01:28 PM Reply With Quote
I'll do a bit of checking later on as i have now flattened the battery, I'll get back to you later
