<<  1    2  >>
Author: Subject: Alloy hubs and bearings
loggyboy
posted on 21/8/13 at 01:44 PM Reply With Quote
Any hints on how to get these in?
I have mk2 escort/capri alloy hubs with bearings supplied with them. I tried tapping them in squarely with an old bearingt shell, but didnt get far. Not sure if pressing them is wise. or would it?
Suggestions welcomed.
Mistral Motorsport
Mr Whippy
posted on 21/8/13 at 02:17 PM Reply With Quote
I had these but didn't find it too difficult to chap the bearing shells in, you could try heating the hubs up in the oven and that should expand the bore and allow you to drop the shells in easily (without the bearings obviously as they'd get cooked)
loggyboy
posted on 21/8/13 at 02:29 PM Reply With Quote
Great idea. just happen to have an old oven in the garage for curing powdercoat so wont even have to get permission from the wife!
Mistral Motorsport
mcerd1
posted on 21/8/13 at 02:34 PM Reply With Quote
I wouldn't heat the alloy any more than you had too (incase it affects any heat treatment - some alloys this is only ~100°C+)
but you could freeze the bearings overnight before fitting them
for most hubs I'd say the press is the best option, but thats for OE stuff not your fancy aftermarket bits....
[Edited on 21/8/2013 by mcerd1]
Mr Whippy
posted on 21/8/13 at 02:48 PM Reply With Quote
Yip good point, doing both should help a lot
loggyboy
posted on 21/8/13 at 02:55 PM Reply With Quote
Also thinking about it more, heating the hub may expand it in all directions, closing up the gap for the bearing rather than opening! Either way, freezing the bearing shells is a good starting point.
Mistral Motorsport
mcerd1
posted on 21/8/13 at 02:57 PM Reply With Quote
^^ the heat generally makes the hole a little bigger overall
but a lot of alloy's don't like getting to hot - even if the heat treatment is ok, you could end up warping it by releasing some of the residual stresses left from the machining, etc.....
(maybe I'm paranoid, but I wouldn't risk it on my own hubs)
also don't forget to use a little oil to help it in
posted on 21/8/13 at 03:19 PM Reply With Quote
A "hole" expands outwards when heated ie the diameter increases.
The bearings are a light interference fit to prevent them becoming loose when the hub gets warm and the alloy expands more than the steel bearing outer ring.
Also with an alloy hub you have to allow a little end float when adjusting to allow for expansion.
Even heat 100c to 120c for no more than 20minutes won't do to much harm to the heat treatment treatment.
[Edited on 21/8/13 by britishtrident]
theprisioner
posted on 21/8/13 at 03:52 PM Reply With Quote
I found a great way to get bearings out of hubs, had the same problem on my puma. Needed to retain the front hubs for the rear on the J15. New bearings of course supplied in the kit. You need a lot of cohonies and a friend with a plasma cutter:
1) Remove as much of the bearing as you can cage and inner roller. Brute force will suffice.
2) Switch on plasma cutter, turn down to minimum and cut across the bearing shell. Now with a lot of luck the breakthrough will be minimum and the shell will drop out.
Worked for me!
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
loggyboy
posted on 21/8/13 at 03:57 PM Reply With Quote
I need to get them IN not OUT?!
Mistral Motorsport
Mr Whippy
posted on 21/8/13 at 04:16 PM Reply With Quote
Heating the hub to 150 degrees is nothing, they get damn hot anyway being bolted onto the back of the brake disk.....honestly
Chuck the bearing shell in the freezer and heat the hub up, the shell will just drop in, I'm sure that was the instructions on my hubs anyway
mark chandler
posted on 21/8/13 at 05:07 PM Reply With Quote
Played a blow torch over my hub, bearing out the freezer and it dropped in with a clunk, 2 minutes later on immovable.
posted on 21/8/13 at 07:20 PM Reply With Quote
Worked for me!
Not sure I would try doing it that way, too easy to end up with a scrap hub. A better way is to remove the inner race and bearings then use a MIG welder on high setting and run a bead around the inner bearing surface of the outer race then quickly turn the hub over to allow the remainder of the bearing to just drop out. Escort or Capri front hubs use taper roller bearings which are best fitted using a bearing drift which takes only a few seconds for each outer race.
Litemoth
posted on 21/8/13 at 10:09 PM Reply With Quote
My two penneth...
Don't go baking hubs or freezing your bearings - the metallurgical properties will be irrevocably changed and reduce the life of the hubs and bearings. The tolerances for most hubs don't require 'sweating' to get them to go together.
Push the outer races in with a press and some decent square tooling. If you haven't got one then get to one. Bashing them in with a hammer and a punch (yes, we've all done it) doesn't do bearings any good at all.
Wadders
posted on 21/8/13 at 11:12 PM Reply With Quote
Originally posted by Litemoth
My two penneth...
Flipping heck Litemoth, He's knocking together a toy car in a shed, not building the next space shuttle
My two penneth...
Care to explain to how sticking a alloy steel bearing in a domestic freezer will (permanently) change its' metallurgy ? -- fitting bearing parts by freezing using dry ice or liquid nitrogen is common practice in industry.
Likewise evenly heating aluminium silicon alloys to the 120c temperature for time suggested followed by natural cooling won't cause problems. In fact this is done all the time when replacing the valve guides in alloy heads. Some engine builders heat cylinder heads to 160c and some claim to go to 200c but I wouldn't go that high.
In this case the outer races won't just drift in the hubs are light alloy and require the the outer race to be an interference fit.
In the past some of designs of after-market alloy hubs sold for Ford stub axles have rendered the hub scrap after a few miles. The reason was when hot the differential thermal expansion between the outer race and the hub was so great allowed the outer race to rattle about loose within the hub
What will damage an alloy hub is bashing at it -- obviously the OP knew not do this or he wouldn't have asked.
Mr Whippy
posted on 22/8/13 at 06:26 AM Reply With Quote
My two penneth...
I'd be quite worried if your freezer was so cold it could destroy the property's of the bearings seeing that most only go as cold as a British winter
My ally hubs were certainly not heat treated and the metal was quite soft, tbh I would not like to have used them on a standard weight car as I reckon they'd bend on a pothole, I was actually replacing bent original steel ones.
[Edited on 22/8/13 by Mr Whippy]
posted on 22/8/13 at 07:08 AM Reply With Quote
Steel like any structural engineering material I can think of does become brittle at low temperatures but this ductile-brittle transition isn't permanent and is reversed as the material warms back up to the normal ambient range. This change from ductile to brittle can with just a small drop in temperature and cause unexpected instantaneous failures --- for anybody interested google on WW2 Liberty ships or T2 tankers.
In the case of a cheap poor quality steel the transition from having ductile mechanical properties to brittle can occur from 0c downwards, however with a high quality fine grained alloy steel that would be used for a bearing race I would expect the transition temperature to be much lower perhaps -50 to -60c way below what any domestic freezer can reach.
loggyboy
posted on 22/8/13 at 07:44 AM Reply With Quote
Its only the shell that needs go in, the acctualy bearings are seperate. I could understand if it was a massive temperature change, (going from oven, to freezer), but domestic freezer is only a few degrees below so probably not much colder than a freezing day in the heart of winter!
Mistral Motorsport
mcerd1
posted on 22/8/13 at 07:56 AM Reply With Quote
^^ what BT said
to clarify why I was nervous about heating the alloy when I design structures out of the stuff we consider the normal temp. range to be -50°C to +70°C, but as BT says a higher temperature would need to be maintained long enough for it to start permanently changing the properties.
(don't get me started on Heat Affected Zones around welds etc....)
as for brittle fracture of the steel we design for -15°C and -25°C all the time (the standards let us go to -45°C if needed) its considered safe as long as you have a good enough quality of steel for the thickness of the material your using (the thicker it is the higher quality it needs to be) - bearings normally are made from good quality steel
I'd be more worried about the seals than anything else.... (and a domestic freezer isn't going to do much to them)
now the more than you wanted to know bit
if you've ever bought steel for you chassis etc. you'll hopefully have noticed it comes in different grades
chances are you've been offered grade S235, this if bog std. european mild steel (235N/mm², the UK version of mild steel is S275 i.e. 17% stronger) or the other common one for box is S355 or 'high yield' steel
but whatever the yield strength of the grade unless it has a little suffix on the end like 'J0H' then its not been tested for brittle fracture and should not be used for any critical application
for tubes they are normally tested to either 'J0H' or 'J2H' and both are ok for structural use at least -35°C
for other sections the come in 'JR' 'J0' 'J2' (and 'K2' for some grades) (in order of worst to best) JR will do -15°C, J0 will do -35°C and J2 will do -45°C
also while I'm ranting on about grades - the same grade is often available to different BS standards:
for small tubes you will probably get offered 'cold formed' sections (only it won't say that, it'll just say BS EN 10219 on the certificate)
it has big corner radii and don't have the residual bending stresses relieved after they are formed (not bad as such, just not as good/reliable as hot finished ones)
the 'hot finished' (BS EN 10210) ones have smaller radii, lower residual stress and are better suited to welding on/near the corners - these are always best if its a safety/strength/stiffness critical application like a chassis
so if you want the best box sections for your chassis they should be grade 'S355-J2H'
(unless your using fancy seamless tubes etc - they have there own standards with different grades and qualities)
[Edited on 22/8/2013 by mcerd1]
Wadders
posted on 22/8/13 at 08:37 AM Reply With Quote
Here, straight from the horses mouth.......
http://www.timken.co.uk/EN-US/products/Documents/Industrial-Bearing-Maintenance-Manual.pdf
Litemoth
posted on 22/8/13 at 12:19 PM Reply With Quote
My sentiments exactly. No need for freezers and heaters on tiny hub bearings then .
I suspect that if it's that hard to push home then the 'limits and fits' on the bearing housing may not be to specification.
If you tell me what the bearing size is then I'll tell you what the bore tolerance is.
Litemoth
posted on 22/8/13 at 12:27 PM Reply With Quote
The horses mouth says:
Never rapidly heat or freeze a bearing or bearing component.
Only use approved equipment, methods and controls to achieve
desired temperature.
Always follow OEM instructions to ensure bearings and rings are
properly positioned after heating or cooling.
loggyboy
posted on 22/8/13 at 01:00 PM Reply With Quote
It also says:
Cooling (Freezing)
Freezing standard class bearings and rings
•• -54°C (-65°F) - 1 Hour
Freezing precision class outer rings or cups
•• -29°C (-20°F) - 2 Hours
Note: This temperature can be obtained by commercial freezer/refrigeration
equipment.
It acctually says 54°C (-65°F) but this is blatantly a typo!
So minus 15 or 20 in a domestic freezer, couple with the fact that going from room temperature to what ever the freezer can achieve is going to be far from rapid.
Either way, an interesting selection of opinions, I will let you know how I get on.
[Edited on 22-8-13 by loggyboy]
Mistral Motorsport
b14wrc
posted on 28/8/13 at 11:21 AM Reply With Quote
I struggled to get my old Fiat coupe hub bearings out, ended up needing a 10 tonne press at a local garage to remove them, the guy had a struggle with them.
I had used the hammer method and made a right mess of it, leaving just the outer race totally wedged!
I have not replaced them yet with new ones, but expect they will need pressing in - hubs are steel though, not alloy.
Rob
20vt powered rear engined locost
<<  1    2  >>
