Author: Subject: s2000 stroker 2400
unijacko67
posted on 22/8/13 at 09:08 PM Reply With Quote
s2000 stroker 2400
Has anyone on here built a 2400 s2000. I've sold a couple of standard s2000 cranks to help fund the build as I have a few old s2000 engines that I've bought as none runners and in bits. I now need some dimensions from the s2000 crank so I can have the new Acura k24 crank machined, flywheel side is easy, but not sure about front end as I seem to think it may need shortening and the keyway extending. Anyone got any spec on the s2000 standard crank.
I can always dry build it up and work it all out if no luck. Its an on-going project and wont be going in the Kitten for quite some time as Ill have to alter ecu and need to find out more about that also. Cheers
http://www.kittenkitcar.co.uk
Bare
posted on 23/8/13 at 02:41 AM Reply With Quote
You've erm.. sold the S2000 crank(s?) you needed to take measurements from.. Genius. .. IF you actually had such.
Foot power pedals are likely appropriate for the Kitten :-)
unijacko67
posted on 23/8/13 at 07:03 AM Reply With Quote
"Genius" its no big deal, its only the length of the front pulley carrier part of the crank, and to be honest I didn't expect an answer, as said I can work it out. I probably didn't even have any s2000 cranks ? then why would I say that. I must be loosing it.
Thank you for all your helpful info.
sdh2903
posted on 23/8/13 at 07:12 AM Reply With Quote
Mr Bare and his array of very useful posts strikes again!
daniel mason
posted on 23/8/13 at 07:34 AM Reply With Quote
some great answers there jacko
with all that info you will have it built in no time!
[Edited on 23/8/13 by daniel mason]
posted on 23/8/13 at 10:08 AM Reply With Quote
One day you may make a useful contribution, or even a non-sarcastic post to the forum, but I'm not going to hold my breath.
Back on topic, I know someone involved in the world of Honda tuning, I'll see if he has any suggestions or advice.
[Edited on 23/8/13 by MikeRJ]
unijacko67
posted on 23/8/13 at 07:14 PM Reply With Quote
Many thanks Mike, good to have some real helpful info and comments regarding the first shitty post.
I'm calming down now as the first reply I had to this post this morning more or less stated that I was a liar and a idiot, its pissed me off all day, but now realise this type of sarcasm and insulting comments directed straight at me are part of the "Forum" scene and maybe not intended to be personal. I try to make my questions simple, but often Goodle doesn't come up with the answers so don't mind not getting any reply.
Let me know what you find out as it could be helpful to others in the future. Cheers
daniel mason
posted on 23/8/13 at 07:38 PM Reply With Quote
id imagine its just jealousy jacko. lots of people can sit at a computer telling people how good they are at building cars.other people like you can actually build cars.and to a better standard than most!
unijacko67
posted on 23/8/13 at 07:53 PM Reply With Quote
Not jealousy, prob just a misunderstanding. No worries.
wylliezx9r
posted on 23/8/13 at 07:58 PM Reply With Quote
Bare has hijacked a thread of mine in the past with similar comments. I wouldn't take it personally he's just a first class prick he'd be better suited to the max power forum (if it exists )
George Best
mark chandler
posted on 23/8/13 at 09:00 PM Reply With Quote
imagine a bore down the pub who has either done something better than anyone else or derides anything anyone else has done...... Bare!
unijacko67
posted on 23/8/13 at 10:12 PM Reply With Quote
Ok this is the end of the s2000 crank that I'm on about replicating with my K24 crank soon to be a s24 crank. I took some pictures before I sold the s2000 crank. I'm ok with it, as I want to get it right so will sort it out myself as I may get reliable info, but may be a different part numbers etc. The plan is to evolve the Kitten's handling along with brakes and fire eater system, get it log booked then itb's along with ecu and then this motor will get popped in. I'm in no panic as I have good reliable standard power at the moment.
bi22le
posted on 23/8/13 at 10:52 PM Reply With Quote
Having never seen a s2000 engine in bits may I ask a question that is bugging me.
What are those sandy coloured lines? One goes straight up and the other off at an angle. They look like chain guard rub strip things but there are no chains near them. They don't look like seals either.
Please read my ring story:
unijacko67
posted on 23/8/13 at 11:20 PM Reply With Quote
Hi yeah chain tensioners/guards, they moved outwards when I removed the front cover if I remember right. This is with front cover on.
s2000
s2000
[Edited on 23/8/13 by unijacko67]
pwl
posted on 24/8/13 at 02:08 PM Reply With Quote
I have an extra F20C crank (changed it to a F22C).
Front end is very close to 46mm
Keyway is about 37mm.
PWL
unijacko67
posted on 24/8/13 at 04:32 PM Reply With Quote
Thanks for the info, my front end seems to be 47mm, but the keyway only 30mm. Good news though as I may not need to do anything to it. I have a mate who can extend the keyway when he skims the flywheel side flush. Did you keep the oil squirters.
Also did you machine the crank big end journal's (not sure if that's spelt right) or take 2mm off each side of the h22 prelude rods
Doing the crank would make the rotating mass quite a bit lighter and keep the rods strong, but it would involve a good bit more work and a re-balance.
As this is an on-going project I'm not in a rush, but have all the parts apart from shells and gaskets. I have planned for a programmable ecu for this motor, but has anyone tried with stock ecu and sensors. I've spoke to other chaps who have stroked different engines and believe standard ecu wont like it. If this would run on standard ecu I would be eager to get cracking, but cant face changing all the wiring just yet as my standard s2000 goes ok. Thanks again, Andrew.
wylliezx9r
posted on 24/8/13 at 05:34 PM Reply With Quote
I wired my F20C using an omex 710 ECU. It was pretty easy and I still have all the notes if you ever wanted them. It doesnt use half the sensors that the stock ECU does either, from memory it uses crank, TPS, Air Temp, coolant temp, and exhaust cam ps. I havent bothered with Lamda feedback (on the advice of Omex).
I simply removed the connectors off the honda engine loom that would have gone to the ECU and spliced in the Omex loom from there. After I worked out which wire went to which the actual physical wiring took about 1/2 a day.
The biggest advantage is being able to set the vtec to whatever RPM. Mine is currently set @ 4500, giving a vtec powerband of around 4000 rpm. On the road the car is very quick and I'm usually shortshifting at about 7000.
On your stroked engine I would definately think you would need an aftermarket ECU as all your fuelling and timing requirements will be totally different.
HTH Dan
George Best
daniel mason
posted on 24/8/13 at 05:38 PM Reply With Quote
is the f22c not a standard item in american s2000's jacko? just a 2.2 litre f series motor?
unijacko67
posted on 24/8/13 at 06:06 PM Reply With Quote
Thanks for the omex 710 info Dan, I've read somewhere as mine (the one in the Kitten) is ap2 07 throttle by wire it might be better on hondata or something like that. I don't know much about any of all these parts Dan M, apart from what Ive read about my project. K24 crank, h22 rods and pistons although I've got some nipon 87.25 frm compatible pistons because the bore had very light scoring and I had the block honed, but will have to check it all out as they state 11.6:1 comp ratio for the 2.2, but I'm not sure that takes into account the extra swept volume with the 99mm crank as it will be 2.4
daniel mason
posted on 24/8/13 at 07:39 PM Reply With Quote
the f22c was a 2.2 litre s2000 in america but only for a year or 2. they made identical power and a bit more torque
Neadles
posted on 24/8/13 at 09:12 PM Reply With Quote
Just a consideration I know from my old honda days and the S2KI forum, that the Americans use a Acura TSX (Accord) crank with H22 rods and standard parts with a little bit of mahcining. This is a short artical on the subject:
http://www.turbomagazine.com/tech/0609turp_honda_f20c_stroker_build/
You probable have this info but might be useful.
unijacko67
posted on 25/8/13 at 10:40 AM Reply With Quote
Thanks for the article , I have got that info and that's what I am basically building, but there is quite a lot more to it as there are so many variables like rods, pistons, pins, head gasket, crank, frm bore or sleeved then itb's and ecu etc.
I've just found this if anyone else is interested http://www.s2ki.com/forums/index.php?showtopic=538548
[Edited on 25/8/13 by unijacko67]
Neadles
posted on 25/8/13 at 07:45 PM Reply With Quote
Yea I know its a lot of work with other things to consider, but have you decided what you want to achieve with power and reliability, would doing an F22 not be better? Or is this more of a case of wanting to do it which is as good a reason as any!?
unijacko67
posted on 25/8/13 at 08:10 PM Reply With Quote
I just think the 2400 will pull like hell and be good on the hill climb scene, and wanting to do it. Just been out playing this evening though and the standard s2000 goes well to be fair. posted a video on my blog, it's funny.
http://www.youtube.com/watch?v=SSwK7FeAvCo
