Author: Subject: Westfield RGB Race Car
Boltsy
posted on 31/8/13 at 10:13 PM Reply With Quote
OK, right, where to begin….Here I am offering for sale, one of the most well known RGB race cars on the circuit. This car has been run by three different racers over a 6 season period, has had over 100K spent on it over the years, however did not run in the 2012 season as rule & regulation changes required a different engine and the previous owner had other plans. I acquired the car last August and proceeded to completely rebuild the car from the ground up at AB Performance, ready for this current season, in which I am running it. The following is a list of items which were installed, suffice to say well over 14k worth of work:
Engine Bay:
’09 Honda CBR 1000RR – 5k miles + 3 RGB Meetings + 2 track days c/w Standard ECU
AB Performance Billet Sump & oil pick up
AB Performance water pump delete kit
Bazaz unit
‘V’ stack air intake trumpets
AB Performance air filter
Bespoke airbox
AB Performance bespoke top/bottom engine frame (keeping weight as low as possible)
Power commander 5 (fuel mapping)
Remote electric water pump
JCC oil catch tank
AB Performance billet oil take off
13 row mocal oil cooler with braided lines
New AB Performance Exhaust System
Fueling:
Sytec High pressure fuel pump
Sytec fuel pressure regulator
Sytec fuel filter
2L merlin motorsport swirl pot
New fuel lines
Facet low pressure fuel pump
Handling:
Protech double adjustable dampers front/rear
200lb 8” front springs
150lb 7” rear springs
Procomp bespoke front Anti Roll Bar
4 x 13” CXR Wheels c/w new Yokohama A048’s (Dry)
4 x 13” CXR Wheels c/w good Yokohama A048’s (Wets)
4 pot AP racing Brakes (F) Sierra (R) & Pads
Interior:
Bespoke Carbon dash
Carbon tunnel
Carbon side panels
Digidash Pro c/w data logger
New switches inc. FIA
Flappy Paddle gear change
New Lifeline Zero 2000 Fire Extinguisher & Cables
MOMO Steering Wheel
Clutch & Throttle Cables
The car has a ducted front end which helps to keep the hot air out of the bonnet area, full undertray, and has been completely rewired. A new bonnet was developed raising the V8 bonnet bulge by 2” to keep the fuel rail of the 1000RR engine under wraps and looks completely as Mr. Westfield designed.
The package also includes many spare parts such as nose cone, steering rack, prop, cycle wings (various), Front wish bones etc. etc. and a fully covered twin axle trailer which has a tyre rack inside. The trailer needs some attention but is in use and tows very well. Made to fit the Westy inside very snugly!
This car has been rebuilt with no expense spared and is a ready to go Race Car. If you have a race licence or have your ARDS test completed, you can be racing this car in RGB this year as I will be if not sold before the end of the season.
I’m looking for offers around 14K for the car or 15K inc the Trailer. If you want to know more, you can call me on 07906 358217 or come find me at Donnington or Cadwell and come see the RGB nutters at their best!
I have over 100 pictures of the car / rebuild & racing so I would be happy to send any out if requested.
Thanks for looking
[img]http://locostbuilders.co.uk/upload/Procomp ARB 2.JPG[/img
[img]http://locostbuilders.co.uk/upload/Flappy Paddles 1.JPG[/img
Limitation starts where the visions end - Jimmy Johnson
HowardB
posted on 1/9/13 at 10:40 AM Reply With Quote
does this mean that you have something new?
I hope that you're not going to leave Kelvin to fix his own car??!
free bump too
Howard
Benzo
posted on 1/9/13 at 11:39 AM Reply With Quote
Best of luck with the sale Kevin!
As above, hope you have a new toy lined up!
Boltsy
posted on 1/9/13 at 02:09 PM Reply With Quote
Don't worry guys, the only reason for selling is to fund the new car for next yr!
Benzo
posted on 1/9/13 at 02:15 PM Reply With Quote
Sabre I hope
Duncan36
posted on 1/9/13 at 04:30 PM Reply With Quote
I was hoping it was my car lol
www.acorn-printing.co.uk
www.tshirtuk.com
Boltsy
posted on 1/9/13 at 04:50 PM Reply With Quote
It will never be a Spire after happenings last meeting at Silverstone. Poor show from Nightingale. 👎
gixermark
posted on 3/9/13 at 08:42 AM Reply With Quote
^^ wheres the like button ^^ !!
jeffw
posted on 3/9/13 at 10:44 AM Reply With Quote
Picture orientation makes for interesting view angles...
onenastyviper
posted on 3/9/13 at 11:15 AM Reply With Quote
What happened?
"If I knew what I was doing then it wouldn't be called research would it?...duh!"
Boltsy
posted on 8/9/13 at 07:51 AM Reply With Quote
Brand new slipper clutch installed yesterday also BTW!
Boltsy
posted on 26/9/13 at 08:53 PM Reply With Quote
The engine in this car is undergoing a complete check over / refresh so it will be absolutely perfect for the new owner.
Xray350
posted on 8/12/13 at 09:43 PM Reply With Quote
Hello is t'he Westfield still for sale?
Eduard
Boltsy
posted on 9/12/13 at 08:48 AM Reply With Quote
Car is sold
