Author: Subject: Drill coolant circuit?
posted on 1/9/13 at 02:14 PM Reply With Quote
Looking to get some coolant over the drill vice, any ideas?
Nothing there just now, its one of these..
mark chandler
posted on 1/9/13 at 03:52 PM Reply With Quote
Make sure the fluid is nice and thin then a big dish under to catch the spillage and try one of these for much cheapness
300L/H Small Powerhead Submersible Aquarium Fish Tank Water Pump Boyu SP-100
It's not as if you will need a lot of fluid.
[Edited on 1/9/13 by mark chandler]
llionellis
posted on 1/9/13 at 09:48 PM Reply With Quote
I use gravity. Small tank with copper pipe with a valve soldered to the bottom, short length of plastic pipe. the tank is attached to belt guard. It's a total loss system and is a bit messy. In truth I very rarely use it on the drill but find it useful on the lathe.
dhutch
posted on 2/9/13 at 05:14 AM Reply With Quote
Garden sprayer, adjusted right out to give a jet...?
DIY Si
posted on 2/9/13 at 09:14 AM Reply With Quote
I just use the bottle my drilling fluid comes in. It only drips out the end if you invert the bottle.
Sun Tzu, The Art of War
Badger_McLetcher
posted on 5/9/13 at 07:30 PM Reply With Quote
If disfunction is a function, then I must be some kind of genius.
Badger_McLetcher
posted on 5/9/13 at 07:36 PM Reply With Quote
A bit more seriously... how about a windscreen washer pump (or similar) linked with a variable resistor in between it and the power supply. Use a container with a hole in it to catch the fluid drain it back to the main container, not forgetting to put a filter of some sort in. You could go even simpler without the return line, but would have to stop frequently to empty the catch container.
I've just reread this an realised it's quite a similar idea to Mr Chandler's, but hopefully that shows it's a good'un
