Author: Subject: R1 Clutch Plates - 2003
spdpug98
posted on 10/9/13 at 03:23 PM Reply With Quote
I'm sure when I originally built my car I was told to put a friction plate in first then 2 clutch plates, then alternate from there until all the plates are in
I've just looked in the work shop manual and that says to start with a friction plate and then alternate straight away - can anyone confirm what is correct and how many friction plates there should be
My Blog: http://spdpug98.wordpress.com/
gaz_gaz
posted on 10/9/13 at 03:50 PM Reply With Quote
13 plates in total, 7 friction, 6 steel.
Friction, steel, friction, steel etc, so you will start with a friction and finish with a friction.
Worth noting that the first friction to be fitted is slightly smaller than the other 6, ie has less friction area
spdpug98
posted on 10/9/13 at 05:05 PM Reply With Quote
Thank you
spdpug98
posted on 10/9/13 at 05:12 PM Reply With Quote
Just checked it again, I have 7 steels also.....
gaz_gaz
posted on 10/9/13 at 05:53 PM Reply With Quote
I bought an EBC kit and it came with 7 of each, I only used 6 of the steels as that made the correct height for the stack in my car and the clutch has been ok for 6k of track miles.
spdpug98
posted on 10/9/13 at 06:07 PM Reply With Quote
Thanks again, I've just pulled the plates out and taken one out
